Canon PIXMA MP150 All-In-One InkJet Printer
Problem for Canon PIXMA MP150 All-In-One InkJet Printer
Mp 145
By dimas323 on May 04, 2008
is there any solution to redetect the cartridge in mp145
error e15
Same Problem
May 04, 2009
-   ink absorber is full-   Guest
Apr 21, 2009
-   My MP145 problem is E3-paperjam,but i dont see any jammed paper in my printer,what would be the cause of this problem?
Thanks
-   foghs78
Mar 05, 2009
-   tidak dapat mengeprint
-   Guest
Feb 28, 2009
-   full ink tank mp145-   dilut_rj
Feb 26, 2009
-   hi i have canon MP145 printer. my problem is E4. but i have already replace the new ink catridge.. what should i do -   ann_kk_83
Best Solution
posted on Dec 24, 2008
Very Helpful)
dtlc7757
Rank: Apprentice
Rating: 100%, 10 votes
How to reset the e27 for canon mp145 printer?
Comments:
Dec 24, 2008
- How to reset e27 problem for canon mp145?
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #2
posted on Aug 13, 2008
Very Helpful)
paramuchrist
Rank: Apprentice
Rating: 97%, 12 votes
After correcting the ink cartidge in proper installed,still E5 is shown in my printer Pixma MP145.Please give me solution.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #3
posted on May 04, 2008
Helpful)
myob247
Rank: Guru  Canon Computers & Networking  Expert
Rating: 86%, 1073 votes
I found this, might be worth a try:
CANON RESETTERCanon MP160 , MP145
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Oct 02, 2008
Helpful)
apple_jun
Rank: Apprentice
Rating: 88%, 3 votes
i losed my driver (pixmamp145) how can i down load?
Was this helpful?
Yes
No
Solution #5
posted on Aug 08, 2008
Helpful)
laddii
Rank: Apprentice
Rating: 87%, 6 votes
please help me find a solution on how to reset my printer MP145. every time i print it e8
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #6
posted on Sep 02, 2008
Very Helpful)
pocket2
Rank: Apprentice
Rating: 96%, 7 votes
hi this is to tell u all that when ur printer starts showing low ink or when it is below normal then get ur inks refilled.
the error e 15 is shown by the computer becoz it is showing the cardriges as empty and the computer has locked ur cartriges theirfore u cannot use it again and u have to buy a new one.even if u get it refilled it won't work....
when it is showing low ink get them refilled if u continue using them without refiling then the ink wil reduce and it will detect and finally when the cartridge is empty it will show u empty and lock it....so keep refilling and use itagain and again......it it is a tactic used by canon so that you need to buy cartridge from them......buy black ink from market it hadly comes for more than a 100Rs and refill it urself through injection.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #7
posted on Oct 20, 2008
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
dear all
we want to know the meaning consist of the botton maintenance A j d,H,Y,P ,UL,b for printer MP 145.
THANKS
Best regard
marhadi w
addres email : marhadiw @yahoo.com
Solution #8
posted on Sep 29, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
how do i install ink catrige
Solution #9
posted on Jun 03, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
thank you so much. i can reset my mp145. but i use step 6. i try step 5 no good.
Popular Solutions for Canon PIXMA MP150 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP150 All-In-One
Do you recommend Canon PIXMA MP150 All-In-One InkJet Printer?
Answer
Answer
there is a problem with scanning documents. when I push scan button nothing happens.
Answer
J.ai toujours un message me disant que lL'imprimante est pas ouverte ou pas connecter et ce n'est... (More)
Answer
Canon pixma MP150 printer waste ink absorber full how do I deal with this.
Answer
I have looked, cleaned as suggested, and no paper jam. It will "bang" slightly and pull a... (More)
13 Other Users Have The Same Problem - Continued
Comment by alburnuni, posted on Jan 25, 2009
Hi, My name is Amri alburnuni from Aceh Indonesia, I have problem with my Printer canon MP 145 which is E27 = Waste ink absorber full or platen waste ink absorber full, I already clean the pleace where ink absorb but still E27.
i also try to press power than press reset but does not work.
please help any of you have solution of my prolem, thank you very much.
Tgk Amri Alburnuni
Pusat computer kotamini beureunuen
Comment by Guest, posted on Jan 18, 2009
reset
Comment by Guest, posted on Dec 29, 2008
Comment by Guest, posted on Sep 27, 2008
i install
Comment by Guest, posted on Aug 15, 2008
hi my printer MP145 had an error E3 and the paper keeps on rolling out what should i do?
Comment by wekie, posted on Aug 13, 2008
mp145 not print red and yellow
Comment by rishu123_200, posted on Jul 14, 2008
hi i am facing e 15 error for my priter mp145 please help
Comment by Guest, posted on Jul 13, 2008
please help me find a solution on how to reset my printer MP145. every time i print it prompts cancel printing contact service administration
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Limited Time Offer!
Canon Pixma MP150 Ink
Save up to 76% on
10% Off All Products.*
When you use coupon:
WINTERTEN, at checkout
Free Shipping on all U.S. Orders over $50
*exp 03.31.2010 excluding OEM ink
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
