Question about Whirlpool RBS305PDS Electric Single Oven
When i turn on the self clean i get an F1 error code after a couple minutes. I have not tried to fix it but i have fliped the breaker off and back on. Nothing helps
  • Whirlpool Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Aug 22, 2010
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
F1 code
Good Afternoon landstardad, thank you for allowing me to assist you!
Typically error code F1 indicates that a runaway temperature (overheating) issue has been detected. Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. If the error code does not clear, at this point, I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Feb 01, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire flashing F1
Hello wills_amber - Typically, error code F1 indicates that the range has detected a runaway temperature issue (overheating). Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) on the range will need replacing.
Mar 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My stove not working and shows f1
Hi mannycarla - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD senor probe and/or EOC and replace if necessary. Meanwhile try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Feb 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
F1 error code Kenmore Elite oven I have no owners manual.
Hi.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
Regards.
Ginko
Sep 06, 2011 | Ovens
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 ERROR
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
Aug 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
Whirlpool RBS305PDS Electric Single Oven Logo
62 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
