Question about Sony CDX-T67 6-Disc CD Changer
I cannot eject the cd magazine - Sony CDX-T67 6-Disc CD Changer
3 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Remove CD Magazine - No power to unit!
u need to re-connect it in order to remove the magazine
Posted on Jun 15, 2008
leethedeuce
  • 4472 Answers
You will need to power the unit to eject the cartridge you only need a 12v source, any car battery etc. Then you just do it like you always do it. It is correct that it is not operating without power.
Wish there was an easier way for you, but hooking it up to power is not to difficult.
Good luck and if you need any other info on the device let me know,
Lee
Stuck CD Magazine
You'll have to take the cover off. Look for screws around the back and on the sides. Most likely a cd is wedged in the wrong place. (not fully ejected) and is preventing the magazine from ejecting.
Jan 02, 2014 | Fisher Audio Players & Recorders
Eject cd magazine
At downside of the music center, right corner, there is a "manual eject system" indicator. just push inside slide to upward with a thin screw driver and your magazine will be ejected..
Jul 03, 2013 | Bose Lifestyle 25 System
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
How do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
May 04, 2009 | Sony CDX-T69 6-Disc CD Changer
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Sony CDX-T67 6-Disc CD Changer Logo
74 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
