Question about Proview PL713S 17" Flat Panel LCD Monitor
I have a proview 22 inch monitor model 2200w it will not come on
  • 11,361 Answers
Check power supply DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 22, 2010
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
How to take apart proview 2200w
The Proview 2200W is made by the same company that make the FPD1975w monitor for Gateway computers. The problem you are having is usually caused by bad capacitors on the power supply board just as you have stated. The problem is that model can have two different power supplies. One board is the PI-190DTLB and the other is the ILPI-021. These two boards use very different parts for the repair. You will need to open the unit and check the board before you order the parts. Here is a link to order a parts kit for both boards, and shipping to Israel is no problem, the kits ship free worldwide. There are instruction guides showing how to dis-assemble and repair many monitors on the youtube link.
Parts kits Here:
http://www.ccl-la.com/catalog/index.php?cPath=21_30
Youtube videos:
http://www.youtube.com/user/cclla1?feature=mhee
I hope this helps you, If you need any additional information just let me know.
Tech@ccl-la.com
Sep 07, 2012 | Proview Computers & Internet
My moniter has a black screen and is blicking blue light. i have a proview model 2200w? Was working fine until i shut down yesterday. I unpluged, nothing happened. Could it be in a sleep mode? If so, how...
this is so common in lcd monitors, its the power suply board.... most likely a capacitor.. so type a model# into google following the words "power suply" it will probably be close to $50-$60... thats better than buying a new one
hope this helps you
Feb 06, 2011 | Proview PL576Ws 15.4" Widescreen LCD...
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
Viewsonic PL2230WDB 2200W Shuts off after 5 seconds
The capacitors in the power supply look good?
It can be the backlight inverter board is going out.
Nov 05, 2009 | Computers & Internet
I HAVE A PROVIEW MONITOR 22 INCH. PL2230 APPROX.
It is out of warranty and not worth repairing.
Jul 19, 2009 | Computers & Internet
Proview lcd monitor has permanent white screen
I had this exact same problem with the 2200W. I was afraid it was the logic board but that wasn't the case.
I replaced all of the capacitors on the power supply board and now it works perfectly. At first I only replaced the bulging capacitors but that didn't fix it. Most of the bulging caps were the 680's and 470's. It ended up being a 220 (which didn't even look bad) closest to the cluster of 680's.
Save yourself some time and replace ALL of the caps. I used this image from a post on this site as my guide: http://www.ccl-la.com/pl926.jpg
Jun 22, 2009 | Ergotech ET-HD1021 MP3 Player
Proview 22
try test the LCD to other PC, if it is working on other PCs, then your VGA card might be the cause. And if the same problem happens to other PC's then the LCD is at fault. Remember to Check the VGA cord. Good luck.
Nov 27, 2008 | Computers & Internet
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
803 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
