Question about Goldstar KG6000R Window Air Conditioner
My Gold Star A/C had a wire trip, I unplugged then hit the reset button multiple times. Now the reset button is not working. Does the Plug have a fuse in the little box I could have blown? And why is it tripping to begin with?
    New Friend:
How do you replace the cord?
Posted on Jun 24, 2013
  • 139 Answers
The safty in the cord is prob bad ..install new plug without safty. homedepot has them.i have had a problem with these so called safty cords .you dont need it thats why we all have breakers so if your breaker didnt trip bad cord
Posted on Aug 22, 2010
My a/c unit keeps tripping when i plug it in. i've tried to hit the reset button on the plug but doesnt do anything. i unplug and plug back into outlet and it trips again. what can i do to fix it?
There is nothing you can do to fix it... the compressor is trying to start and cannot so it trips the plug. The plug trips to protect the house circuit from being overloaded and causing a fire.
Getting the compressor replaced is cost prohibitive, it is cheaper to buy a new unit.
heatman101
Aug 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
Dryer stopped in the middle of a cycle. Time kept going, drum and motor stopped. Unplugged dryer, check lint and exhaust hose for build up. Plugged dryer back in, when I select time and hit start, dryer...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Mar 12, 2011 | Bosch Nexxt 500 Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
My 24 digital timer its not working! isnt there anyway to reset? it doesnt show anything on the screen!! why?
If plug-in timer does not display, then
1) Reset button has tripped > push reset with paper clip
2) power is off > plug something else in receptacle to check receptacle
3) timer is loose in receptacle > unplug timer, spread prongs a bit, and plug back in
4) timer has gone bad.
Except for a few Woods and Intermatic outdoor timers, plug-in timers have internal rechargeable battery. Battery is not replaceable so when battery goes bad, the timer is bad.
See other Woods plug-in timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
59203 plug-in timer at Amazon for $12
http://www.amazon.com/Woods-59203-Digital-Appliance-Repeats/dp/B001Q9EFU0
If you buy a timer, save the instructions like gold so you don't have to write fixya next year looking for instruction that nobody can find.
Nov 19, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Canon IR1510 ERROR: E0000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Hit Additional Functions Key
    2. Hit # key
    3. Arrow to number 7, Printer and hit Set
    4. Arrow to number 4, Printer Re-Set and hit Set.
    5. Yes, re-set printer (hit minus key - back arrow).
    6. Unplug the machine and plug it back in.
Feb 22, 2010 | Office Equipment & Supplies
The power does not work. Is there a reset button.
If you have already reset the fuse, unplugging the unit for a minute or two should reset it. Inspect the internal for loose wires, wires with bad insulation or burnt parts which may have caused the fuse to trip.
Dec 13, 2009 | Televison & Video
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Possible power supply problem
Open your computer case and disconnect/remove any hard drives, cd-rom/dvd drives, take out any extra cards installed (except video card unless you have onboard then take out the video card too) and all but one stick of ram. Turn the computer on
- if it turns on, plug in each item back one at a time turning back on and off each time ( power trip will cause the pc to not turn on)
- if you smell anything weird from the PSU unit DO NOT try anything further, replace the unit.
- if you have overclocked your computer, use the jumper on the board and reset your bios
In the event you need to replace your PSU unit if Antec is an option, go with that. They are very stable.
Jan 21, 2009 | Dell Computers & Internet
Goldstar KG6000R Window Air Conditioner Logo
227 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
