Question about Dacor DMT2420SS Microwave Oven
Dacor DMT2420S Microwave has light and touch pad fully functional but when you push start, the clock counts down normally but no sound of the oven running nor does the turntable turn. Food does not heat. Any chance of repair or must it be replaced?
  • Dacor Master
  • 9,098 Answers
Simple fix.
You need to replace the bottom door switch, or repair its loose or broken mount.
See this help file on door switches, and refer to the service manual here for disassembly help.
You can find part numbers here and order Dacor parts (by part number only) here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Aug 22, 2010
Latch on Dacor micro (DMT2420S) not engaging sensors.
The latch interlock may be defective or in need of adjustment.
Dec 14, 2017 | Dacor Microwave Ovens
We have a Dacor Microwave DMT2420S that everything works except the Touch Screen doesn't light up.
The display board is bad, it may be part of the control PCB or it may be separate. Some are back lit and some are lit internally.
Oct 21, 2013 | Dacor DMT2420S Preference 24" Microwave...
The Dacor DMT2420S microwave has power. Instrument dial is lite and the timer works. I can program the keypad however the turntable will not turn and the microwave will not work. The timer will count down...
There's no reset button, and if the fuse were blown, the oven would be totally dead.
Your problem is almost certainly a failed secondary interlock (bottom door switch) or its mount.
You can see our help file on door switches here and the service manual here.
Jun 20, 2011 | Dacor Microwave Ovens
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
Dacor DMT2420S Blank display, oven does not work
It sounds like you need to have the control panel assembly repaired or your CPU unit replaced and you need a new bottom door switch.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Or you can order our exclusive modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30. It comes with a one-year guarantee. See details here.
We have the service manual and have uploaded it our site here to help you. It covers disassembly.
Also see this file.
You can order a universal type switch here for $5 postpaid.
Feel free to contact me directly for more help and information.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 02, 2010 | Dacor DMT2420SS Microwave Oven
The touch screen on our Dacor DMT2420S is lit, but there are no "buttons" to use to control the microwave. None of the other buttons work either.
We have very good success with these models.
William E. Miller
prototech@usa.net
Jan 30, 2010 | Dacor DMT2420SS Microwave Oven
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
300 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
