Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex Salt Water System for Above Ground - stuck on code 88
  • 106 Answers
SOURCE: Just added an Intex salt water Gernerator to my
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Posted on Apr 18, 2010
  • 2841 Answers
SOURCE: I need a manual for the salt water system
You can download the manual here for free. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143 Have a great day.
Posted on Jun 01, 2010
Testimonial: "Wonderful, just what I needed. Thanks a lot!"
SOURCE: I keep getting code 90 (low water flow) on my
I had the same problem. I cleaned and then changed the filter, cleaned the sensor, everything the book said. It ended up that there were leaves and stuff clogging the strainer right as the water leaves the pool and goes into the hose on the way to the filter. Check there.
Posted on Jun 22, 2010
  • 297 Answers
SOURCE: I just got an Intex automatic Salt water system
hello
you are looking at about 135 pounds to start
Bags of salt are usually 40 lbs
Buy 4 but only put in 3 to start.
You need to get 99%pure pool salt sold at walmart and pool stores 6-10 dollors.
Also get a test kit for salt and get your pool to 3000ppm
only filter for the first 24 hours or so until pool registers the 3000ppm no more than 3800 and no less than 2700 lesser amounts than 3000 does not produce enough sanitizer when you generate. Now that you are close to the 3000 you can generate chlorine.
Use this web page to further assist you
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Posted on Jun 25, 2010
  • 297 Answers
SOURCE: Green water with salt water filtration system- HELP
you can not blindly just add salt
you need a salt test kit that reads #'s, not color
Get your salt content to as close to 3000ppm as you can any lower than 2800 and you will not produce enough chlorine and any more than 3500 and it will taste bad and could make your water cloudy or trigger high salt alarms
Also remeber to run filter only for 24 hours after adding salt
you also need to realize that a pool goes green for many reasons lack of sanitizer,heat,sun,rain,sun tan oil, 3 of swimmers
A pool need to be turned over at the bare minimum of 3-4 times in a day.
Intex filters are not sufficient to properly do the task
only a good sand filter and seperate pump of about 1 horse will really keep a pool sufficiently cleand but if you follow my advise you can do it with the intex
lets start with the filtering I believe your pool is around 5000 gl
if you have a 2000 gl ph pump then you need to be filtering 7 1/2 -10 hours just to keep your pool clear you do the math for you
as for grnerating your chlorine time varies depending on the situations I mentioned earlier
it is good you are using a stabilizer but that only goes so far if it was hot and sunny and a lot of use chlorine will get ate up any way
And make sure your algaecide is a non foaming kind and stick to the directions
now to your problem at hand
you now need to as you did shock it but you also need to use a lot of elbow grease and remeber this is going to be tedius
Clean your cartridge with the garden hose blast it in the folds as hard as you can
start your filter again and now add 2 gallons of chlorine or house hold bleach
let filter for 12 hours and then with a pool brush not the bristles under your vacuum head scrub the sides and walls continue filtering until you see the settled algae and then vacuum
now clean your cartridge again and repeat if the chlorine is still high you do not need to add but if it went low again then add 1 more gallon
continue doing this until you can see a huge difference
once you can then start with your algaecide again
at this point overdose it as directed on the bottle once your chlorine is low enough to get in then you need to get in and brush under the seems
with the intex liner there are too many seams and folds that need to be addressed
another hint is to have 2 filters one drying while the other is in the unit
a wet freshly cleaned filter does not work and trap particles as well as one that has been dried
Another good chemical to use is a water clarifier this helps minute particles that you can not see clump together thus making it easier for thr cartridge to trap
good luck and if you have any more questions you can e-mail me through this site
Posted on Jul 09, 2010
Testimonial: "Was very helpful, very knowledgeable, unfortunately fairly impatient about being "rated" and called me an A**hole because I hadnt yet rated him due to being sick. (and the fact that I didnt know I even needed to) Thanks for the advice though!"
I turn on salt water system and stays on 88. I cannot find my owners manual. My water is turning green. Model 8110
Here's the link for the manual... Code 88 is the start up mode.. You set your cycle from here...
If you need further assistance after you find your manual, reply and I will help sync your pump and chlorinator...
Good luck!! and hoped this helps you...
Please vote and rate...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=14313&hid_windowname=null
Jul 29, 2011 | Intex Automatic Salt Water System for ...
What does the error 88 code mean
88 is not an error code. This means filter only
Jun 17, 2011 | Intex Automatic Salt Water System for ...
Code 8
8? there is no 8 It is 88 when in filter only mode
If this continues you will need to find your receipt if it is under 2 years old call Intex
They will e-mail you a claim form
Fill it out fax it back and you will have a new one at your door in a few days
Jul 24, 2010 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
My unit turns on, flashes 88 and then goes dead.
Question
What does code "88" mean? What should I do if code "88" appears?
Answer
What does code "88" mean? What should I do if code “88” appears?Code “88” indicates that the saltwater system is standing by, please simply set the operation hours according to the manual and the system will start working.
Jun 21, 2009 | Intex Automatic Salt Water System for ...
The system is stuck on 88 and chirps when the up
THIS IS COMMON PROBLEM FOR 8800 SERIES TURN POWER OFFFOR 10-15 MINUTES TURN POWER BACK ON THIS HELPS RESETTING IT HOPE IT HELPS
Jun 14, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
110 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
