Question about Acer Aspire RC500 PC Desktop
Power Supply Failure ? I plugged a USB into front panel and lost all power,Is there a fuse or has the supply blown
  • joecoolvette
    joecoolvette Aug 23, 2010
    No fuse. Smoked the 5 volt power rail of the Power Supply. (USB ports use 5 Volts) The Processor also derives it's power from that 5 Volt power rail. Time to replace the Power Supply. Also of course, do not use that Front Panel USB port again, and/or do not connect the same device to any of the USB ports. Acer's are known for low quality Power Supply's.
    Problem Solver:
  • 15 Answers
It could very well be a power supply issue. Try narrowing down the source of the problem:
Does this power problem no matter what USB device you plug into your computer? If it is just one device, then it is something wrong with that particular device. I'd recommend replacing or getting it repaired.
If it happens with all devices it could be a problem with the power supply or USB port on your computer. Try a different USB port on your computer or have it looked at by a local technician.
Posted on Aug 23, 2010
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Where is the reset or fuse on the lc391eme tv
The fuse is located on switched mode power supply board. If the fuse has blown the set will be dead no standby led light on front of set also when you plug the set into a power outlet you should hear the relays clicking. if you don't hear the clicking then the fuse has blown or another part of the power supply has failed and will require service.
Apr 27, 2014 | Emerson LC391EM3 39 in. LCD HDTV
Won't turn on
if no any light indicator at the front panel of the monitor, the cause would be power supply failure. to do the check up, you must need to remove the back cover. the power supply board it was connected the power cord. look for a blown fuse and a bulging electrolytic capacitors at the power supply board.replaced those bulged capacitors, you can find at www.digikey.com for parts replacement.
Nov 17, 2012 | ViewSonic VX2255 Monitor
HOW DO I GET MY ISYMPNONY 19 TO TURN ON?
if no any stand by power indicator at the front panel, you must check power supply failure look for blown fuse. if their is a blinking light replace bulged capacitor in the power supply board.
Aug 30, 2012 | iSymphony LC24IFH7PB LCD TV
There is no power getting to the tv. The tv just went off while watching it
if no stand by power indicator in the front panel it was an indication of power supply failure. replace blown fuse at the same time you must check other component that cause the fuse to blow. like shorted fet transistor and bridge type diode.
Aug 16, 2012 | Envision L32W761 32 in. LCD TV
The power does not come on when the "On" button is pushed. What's the problem?
Hi:
Check near the power input connector for a small fuse compartment, the line protect fuse may be blown and in need of replaceing. If there is none then the power supply is not getting power the fuse may be internal to the unit. Or the pwr supply has failed entirely, but check the simple solutions first, usually no power is due to the printer being plugged in an switched outlet or blown fuse or power supply failure.
Aug 24, 2010 | HP LaserJet 5si mopier Printer
I plugged in the power cord and I get no power at all. No lights/nothing? Thanks.
HI
ITS PROBLEM OF COMPUTER SMPS (SWITCH MODE POWER SUPPLY) REPALCE IT ..
TNKS
RABBANEES
Nov 05, 2009 | Dell OptiPlex GX260 PC Desktop
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Acer Aspire RC500 PC Desktop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
