Question about Westinghouse SK-32H240S Television
Does the Westinghouse SK32H240S have the PIP capability on it.
    New Friend:
Some wh sk32h240s doesnt have pip! there were 2 version of the same tv only the diffrence is pip is on graphical menu and the non pip only have text menu darn!
Posted on May 19, 2013
Yes, it has pip. Use the menu to select the pip setting.
Posted on Aug 27, 2010
4 Suggested Answers
  • 718 Answers
SOURCE: No pictrue
Is the LED light purple ?
I have only read bad things about this model. Here are some of the things I have come across. Try this first. With the TV on, unplug it, wait a few seconds an plug it back in. You may also turn off the energy saving mode.
Beyond that the problem could be one of four problems;
1) Bad cable connection to inverter board. Make sure all cables are firmly seated.
2) Inverter board is bad.
3) Power to inverter board is bad.
4) CCFT(cold cathode fluoresent light) has problems.
Posted on Mar 12, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
  • 5421 Answers
SOURCE: what's the vesa pattern for
The SK-32H240S has two sets of mounting holes 75mm x 75mm VESA or 100mm x 100mm VESA mounts.
I hope this helps. The manual is available here: http://www.retrevo.com/support/Westinghouse-SK-32H240S-TVs-manual/id/2727ag925/t/2/ . You will need to enter a code to download the pdf.
Posted on May 19, 2011
I have a westinghouse flat screen tv model sk32h240s that has no picture but sound works. I have replaced a bad transformer and checked and replaced all the capacitors that were bad. What else should
Depends on what type of input your using. Maybe try dif cord( hdmi,component video or composite video) or try dif input on tv. Verify source has video out on dif tv or try dif source.
Jul 25, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a westinghouse sk32h240s. wont turn on and no amber light.
First try a new power cord for the TV. If that doesn't solve the problem, the power supply has failed. (Possibly one or more capacitors on the power supply board have failed. Alternatively, a fuse, zener diode or resistor that works as a fuse has failed) You will need to open the tv and inspect the power supply. Westinghouse TVs use a number of different boards. If you want to replace the entire power supply, you will need to note that exact part number on the label. ShopJimmy has refurbished and used power supplies for this model: http://www.shopjimmy.com/westinghouse-sk-32h240s . The used ones are from TVs that were damaged in shipping and thus have minimal use. http://www.partstore.com/Model/Westinghouse+Digital+Electroni/Westinghouse+Digital/SK32H240S/Other+Remotes.aspx also has replacement parts.
I hope this helps.
Oct 03, 2011 | Westinghouse SK-32H240S Television
What's the vesa pattern for westinghouse sk32h240s tv???
May 19, 2011 | Westinghouse SK-32H240S Television
Where do I locate a replacement power supply for a model SK32H240S
power supply part number 56.04264.001 is NLA which subbed to 4900253180. Best bet is to buy it on ebay
May 27, 2010 | Westinghouse SK-32H240S Television
What is the latest firmware vesrion available SK32H240S ?
Their isnt any as a matter of Fact westinghouse does not have replacement Display Panels there for making them Non repairable.
Dec 02, 2009 | Westinghouse SK-32H240S Television
Mar 28, 2009 | Westinghouse SK-32H240S Television
Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
Nov 22, 2008 | Westinghouse SK-32H240S Television
Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Televison & Video Logo
169 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
