My epson stylus color 450 is getting a connection error when connecting to my msi mother board and my processor is amd athlon 64 .I used to use the printer long time back but it was kept unused for 2 years .i have lost my cd but i insatlled the driver from epson site but i am getting a connection error saying to change the port.does my board support this printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
i also have a hp sacnjet 2200c which was also unused for long i lost its cd and usb cable can i reuse it
