Dometic Duo therm RV a/c rooftop unit. 15,000 btu with heat pump. model 620515. age 5 years. Problem- will not always stay ON. Starts and cools fine. but shuts off within 5 mminutes sometimes.. or will run for hours and hours with no problems. when it stops, I can sometimes restart it by cycling thermostat.. if that does not work I can unplug thermostat from 12v power and then it starts when asked to. Have replaced computer circuit board and wall thermostat.. no change.
  • 68 Answers
SOURCE: btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Posted on Mar 30, 2009
  • 534 Answers
SOURCE: my dometic duo therm brisk air RV a/c unit is not cooling the RV
clicking sound could be thermal overload on the compressor. If the compressor has gone out the unit will not cool the clicking sound is possibly the compressor trying to reset but if the compressor has "gone to ground" (winding burnt out) you will need to have the compressor replaced. Good luck on your repairs hope this helped some
Posted on Oct 27, 2009
  • 6674 Answers
SOURCE: Front AC unit will not turn on
The clicking tells me the AC(hydro) power has been turned off to it. Check all breakers, and make sure if you have another switch on wall, to change from front, to back, or to both, that it is in proper position.
Posted on Apr 18, 2010
  • 415 Answers
SOURCE: looking for wiring diagram for a duo therm by
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
Posted on May 19, 2010
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
What size ac 59516 331
15,000 BTU. Here's a link for you.
Jul 13, 2014 | Dometic Rooftop RV Air Conditioner
Rv ac unit blowing warm air not cool air
if fan is on auto and on cool bad cooling unit
Jul 06, 2012 | Dometic Rooftop RV Air Conditioner
What model number Dometic AC unit to add to RV?
usually 13,000 in front but if enough power and you don't mind the more expensive one go 15,000
Jun 26, 2012 | Dometic Rooftop RV Air Conditioner
A/C starts, goes immediately to heat
Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
Hope this helps,
Rate me please.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
