Question about Whirlpool LEV4634JQ Electric Dryer
Dryer spins and produces some heat but clothes do not dry
    Champion:
  • 245 Answers
Check for obstructions in your outer vent line. This ussually the problem.
Posted on Aug 22, 2010
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Dryer spins but wil not produce any heat to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Frigidaire GLER341A Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Dryer makes a loud rubbing noise as the drum spins and produces no heat to dry clothes. Im not sure exactly what the problem is.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 13, 2010 | Dryers
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
Will no longer spin clothes dry
If it not spinning check the belt and tensioner. If it does sdpin and produces no heat replace the spark ignitor
Apr 06, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LEV4634JQ Electric Dryer Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
