Question about Whirlpool GEW9200L Electric Dryer
Whirlpool Duet dryer runs for 1 min. and then shuts off with e1 error, I did some research and found out their is a thermal fuse located behind the lower panel. Also something about a the heater could be damage. Thank you for your help. Robert
  • 347 Answers
E1 error code is a problem with the thermister sensor is is located behind the lower front panel..you do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Posted on Aug 22, 2010
Testimonial: "Thank you so much for your advice. I'm going to purchase the thermal fuse as well, for the extra few bucks its well worth it. I'll keep you all posted"
What is error code E1 mean
i'm sure you already found out that you have or had a bad thermister located on top of the blower wheel housing,just answering this in case somebody else has this problem.e1 error code is bad thermister
Sep 30, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer GGW9250PW3?
On thing I have learned as a WP tech for some models the service manual does not explain the error code has to be reset to get unit to operate for dryers normally the tech sheet is up in the control panel
Aug 28, 2014 | Whirlpool Dryers
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo Duet Dryer is flashing an error code of E1. What does this mean and what is the fix?
E1 Thermistor open Replace thermistor if found defective
replace the thermistor on backside of unit behind back panel... i think its part number 8577274 you can find this on repairclinic.com, or searspartsdirect.com, or you can shop locally, let me know how itt goes
Mar 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer no error message but drum won't turn
take the bottom panel off and make sure the belt is attached it would be located to the left rear attached to a pulley and a motor. you also could have a blown thermal fuse which you would have to unplug unit from wall take the bottom panel off remove the lint screen then remove the blower housing this is what the lint screen sits in I think it has3 1/4 inch bolts you need to remove directly behind that you will see a white flat thing with 2 red wires going to it. remove the wires and check continuity. let me know how it goes
Jun 05, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
351 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
