Question about Zanussi Dishwashers
I have a zanussi ZSF2440s dishwasher, runs a program ok but wont heat water or dry, heater and wiring all ok, have changed controller but fault still persists
  • tim_scoones Aug 23, 2010
    Are there any Zanussi specialists who can help with this ?, the heater circuit is good but the controller won't turn the heater on, I have already replaced the controller and the fault still persists. The resistance of the thermister at 18 deg.C is 5.7k Ohm, is this correct ?
  • tim_scoones Aug 25, 2010
    Hi, thanks for your reply, yes it is similar to this, mine is a small stainless steel tube fitted in a branch of the circulation pump hose, two wires go to the controller and these check out ok.
    The NTC thermistor measures 5.7k Ohm at room temperature and if I warm it up the resistance starts to reduce as it should but I don't know if the resistance value is correct.
    There arn't any actual thermostats in the machine except overheat protectors on the heater itself and these test out ok.
  • Zanussi Master
  • 3,247 Answers
Looks like the program detects the water is already heated. Have you checked the thermostat element?
Please post a comment so that I can help you further.
Posted on Aug 24, 2010
  • Sam Aug 24, 2010
    Can you please confirm if the thermistor you are mentioning looks like this.
  • Sam Aug 25, 2010
    I find it hard to understand why there would be no thermostat to control the heater temperature. Does the dishwasher not have wash cycles with different temperatures?
    Test the continuity between the thermistor connectors and the controller / timer terminals. Wonder if there is an open circuit somewhere which is giving false signal to the controller. I am not a zanussi expert so maybe I should not provide any more consultancy on this problem. You have already looked at the most obvious items.
  • Zanussi Master
  • 19,396 Answers
Hi.
Test and eventually replace either thermostat or heater. They can be tested reading impedance at their contacts. If there is no continuity (circuit open) then the part must replaced. Start from the thermostat that fails quite often.
Posted on Aug 22, 2010
MY ZD1 6053 BUILT IN DISH WASHER DOES NOT WASH ON ANY CYCLE WITH HOT WATER BUT WORKED ON A BIO PROGRAM FOR TWO MONTHS
Hello
Ok normally a fault like this is either 1 of 2 things either the heater or the main control board.
To check the heater you will need to pull the machine out and remove the right hand side panel and the top.
From there you will see the heater cyclinder towards the back. Pull the wires off the heater and with a multimeter meter the heater out. If faulty then the heater will need to be replaced.
If the heater is fine then take off the front plastic control panel and take the board out. Open the plastic casing unit and take the board out. Have a look at it and see if theres a burn mark or dry joint on the board. If so try and resolder it and see if this cures it. As sometimes the heater relay gets a dry jand casues it not to heat up.
If the board looks ok but the heater and wiring is fine then its more then likely going to be a faulty control board.
Sep 10, 2011 | Zanussi Dishwashers
Dishwasher will not heat water
You will need to find the heaters and disconnect the power line to the heater coil element. Now check the continuity of the coil using a multimeter, if open the coil must be replaced. if there is resisitance then check the line to the controller unit , connect the washer and switch on and check the voltage when the program cycle is on the heat wash. If there is no voltage the relay would have failed or a fault in the controller unit drive.
Aug 12, 2011 | Zanussi Dishwashers
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
Heat Dry - Normal - Heat Dry - Normal or
High Temp - Air Dry - High Temp - Air Dry
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
ZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR DRYING
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel P31bf5e2.jpg
Apr 12, 2009 | Zanussi 24 in. DE6850 Free-standing...
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
No heat
You should check for 115/220v on heater tags, In case you don't have it, your problem is a malfunction thermostat that should be replaced. Good luck!
Dec 06, 2006 | Zanussi 24 in. ZSF6120 Free-standing...
Dishwashers Logo
107 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
