Question about Bosch T-Shank High Speed Steel Jigsaw Blade
My blade falls off from my black& decker Jigsaw after I start cutting,it wasworking ok but could it be too hot?
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
Posted on Apr 10, 2009
spec666
  • 3 Answers
SOURCE: blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
Posted on May 31, 2009
  • 7 Answers
SOURCE: I bought a used black & decker jigsaw no. 7548
several methods 1) turn collar near top of blade. spring return. same in reverse to insert. 2)Older type may have spindle screw which draws up collets to clamp blade. access to screw may be through body directly over blade shaft. thats all for now.
cheers
Posted on Aug 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: I do not know to use the black and decker jigsaw.
Draw the circle pattern on the wood where you need it. Drill a 1/2 or 3/8 inch hole inside the circle, near the circle line. Insert the jigsaw blade into the hole and start cutting, following the line.
If you have the scrolling feature on your saw, don't use it, lock the scroll.
Posted on Sep 20, 2009
  • 6 Answers
SOURCE: I have a corded Black and Decker jigsaw, that is
Don't bother. Return it to the store where it was purchased. No tool should malfunction that early in its life.
Posted on May 26, 2010
What kind of blade for Black and decker #7580 variable speed 3 amp jigsaw
A jig saw blade. There may be some reason why only a B & D blade should be used.
Sep 22, 2016 | Saws
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
When cutting straight with my jigsaw the blade floats even though it is in the lock position
There is a speed and angle ratio that must be observed . Depending on the density of the material and the thickness. The shoe plate can be raised or lowered to assist with the forenamed floating condition. Proper blade selection and sharpness is essential.
With thick materials pushing the blades design, speed and force must be regulated through patience to provide the accuracy you demand. The complete blade system is another part of your investment . Understanding what and when can overcome fast if problems arise. Assuming all of this is in your tool box. I always have been taught. Only adapt when all reason is exhausted.
The last part I have had happen is vibration and tool integrity. Maintaining a tight fastener system all over the tool by lubrication is paramount from use or lack of it. Preventive measures spot stuff from happening when you are making the million dollar cut. But we all know that. Daily or startup practice. Just like stretching before playing, a great coach takes the time to do it for their selves too.
There are six JS700 models. Here is a place for parts should that arise Black Decker Jigsaw Replacement Parts Repair your Black Decker Jigsaw... . Furthermore, here is some words for those who are new at the application. Take a look. How to Use Jigsaw basic. This next look in video instruction is thorough and shows intermediate techniques with some experienced foundation. How to Use Jigsaw produced by skill. The Woodworker Journal places the top six picks side by side in the last video offered Top Shelf Jigsaw Review . There is one called a "Mafell" which has a so called perfect orbiting system, which some make it, the straight cut King.
I took the time to do this on the first day of summer. There is lots more to discuss. I think you have the most versatile easy to learn tool in your shop. I am almost sure you think so too. Keep humming. Fare. Well.
Mar 28, 2014 | Saws
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Sep 20, 2009 | Black & Decker Saws
Borrowed a B&D jigsaw model 7571 want to know how two use the other speed and how to put the blade in properly....does not seem to cut without great force....Cindy
arrowred.jpgExclusive Quick Clamp® tool free blade change provides easy, tool free blade changes
arrowred.jpgAccepts U and T shank blades for use with your preferred blade
Aug 15, 2009 | Black & Decker Saws
Bosch T-Shank High Speed Steel Jigsaw Blade Logo
74 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
