Question about Kenmore 73952 Gas Dryer
Kenmore Gas Dryer Model Number 110.70882990. I must replace the Fabric Dryer switch but am not able to remove the two plastic trim caps and end caps that hold the console panel together. Please help.
    New Friend:
  • 37 Answers
Iwopink --
First you need to remove all the sheet metal screws on the console back panel. The plastic side trim cap pieces are clip-fit. Look carefully at the dis-assembly diagrams online.
PDF service manual is available for download at:
[http://www.allrepairmanuals.com/kenmore-dryer.htm?model_number=110.70882990]
Replacement parts are available from:
[http://www.searspartsdirect.com/partsdirect/]
Owners manual is available at:
[http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=11070882990+KENMORE]
If you are still having problems, write back. -- SWT
Posted on Aug 22, 2010
SOURCE:
Dryer belt keeps breaking
Did you check the idler pulley to be sure it wasn't damaged in some way, like a break in the plastic wheel or metal causing it to cut away at the belt until it breaks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Dryers
My kenmore gas dryer end buzzer goes off and dryer shuts down before cycle is complete
Instructions Things You'll Need:
  • Kenmore gas dryer
  • Vacuum with hose attachment
  • Replacement fuse, if necessary
    Dryer Not Heating
  1. Remove lint from your dryer's lint screen. Remove the lint screen from your Kenmore dryer and vacuum the area behind the lint screen with your vacuum's hose attachment.
  2. Check to make sure that the dryer temperature is set appropriately, and has not inadvertently been turned to "Air Fluff."
  3. Ensure that the gas valve on the supply line to your Kenmore dryer is completely open.
  4. Check the room temperature in your laundry room to make sure that it is at least 45 degrees. Your Kenmore dryer will not operate properly at temperatures below 45 degrees.
  5. Make sure that the dryer outlet grill is not blocked by a fabric softening sheet.
  6. Dryer Not Running
  7. Check to see that the dryer cord is properly plugged in to the electrical outlet.
  8. Check your fuse box to make sure that the fuse is not blown, or check your circuit breaker to make sure that it has not tripped. Replace the fuse if necessary or throw the circuit breaker.
  9. Check the outlet itself to make sure that it functions properly by plugging in a portable device.
  10. please comment on these solution on how it works by rating or voting.
Dec 30, 2010 | Kenmore Dryers
Dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with
a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one
direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Oct 31, 2009 | Kenmore Washing Machines
Start switch access
The console has removable end caps. The white plastic end caps lift off by prying on the top from the back of the console. Sometimes inserting a flat screwdriver in the slot at the top in the back of the end cap and carefully prying upward, makes it easier to pop them loose. The cap will pull off towards you as you are facing the unit from the front. Once the caps come off, there is a screw under each one. Loosen the screws and the panel it will lift up. There are some excellent exploded view diagrams that you can reference at searspartdirect.com. Just type in the model number you provided and look under the "Top and Console" heading. The end caps I'm talking about are listed as items 14 and 18.
If you have any questions, please let me know. I hope you finds this information helpful.
Aug 21, 2009 | Dryers
Agitator dogs stipped
the way to do this depends on if it is a dual action or triple action agitatior.
dual action
- Remove fabric softner dispenser
-pull off plastic cap with flat blade screwdriver
- bolt is under plastic cap 7/16"
triple action (bounces up and down)
remove fabric softenr and plastic cap
with a 1/2" drive socket extention, put into square hole and unscrew spring assembly. once unscrewed top portion of agitator will come off
May 27, 2009 | Washing Machines
How do I replace the door switch on my Kenmore 70 Series dryer? I can't seem to get at it?
most people just bypass it,remove the 2 head screws one on each side (you might have to snap off the plastic end caps,flip the head up,you will see the lid switch jack in the middle,unplug it and cut the 2 outside wires and wire them together,plug back in and your done-mike
May 08, 2009 | Kenmore 63942 Dryer
Taking the front panel off.
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore 98702 Stacked Washer/Dryer
Broken door switch
on the corners of unit console ,,are plastic end caps,,pull them of with your hand ,,grasp it and tug hard,,now you see 2 a scew under each cap..remove screws ,,than flip the console back...now under the console theres three screws holding lid dowb,,remove them slide lid forward ,,,but screw for door switch are on the bottom of front door panel..always unplug first...onthejob
Jan 15, 2009 | Kenmore 63942 Dryer
Kenmore 63942 dryer
remove plastic caps on each end of console by pulling forward at top remove screws in each corner pull console forward and roll back..locate small black relay with 2 blue wires and one with large red wires switch them if dryer works change the one that had blue wires originally if still not working may need to replace even heat board where all those wires go back to ..look for possible burnt spot on it
Aug 27, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
183 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
