Question about Arris DCT6200 DTV Receiver
Channel 0 is the only channel we get now, if you enter another channel by using the remote or manually it will return to channel 0
You need to have it uploaded by your cable provider
Posted on Jan 01, 2011
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: http://s3.amazonaws.com/szmanuals/d29a408ae8fdecdc0547a724183146ef .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Jul 11, 2011 | Radio Shack Pro-96 Scanner
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Puppy completely destroyed our remote,we have dish network also, in the process of eating remote she changed setting to cable and it needs to be on analog,so therefore all that is on screen is fuzz. Is...
With the other Mintek remote that is still intact first try to change the channel on the smaller Mintek television. Usually the remotes have a . or - in order to accommodate analog or digital channels. So directv is usually channel 3.0/3-0 or channel 60.0/60-0 or sometimes another channel as advised by direct tv. Try pressing 03 first or 60/61/whatever channel you are supposed to be on. If that doesn't work try 3.0/3-1 and then the enter/ok key. Try the channel up and down button as well.
Dec 05, 2010 | Mintek DTV-263 26 in. LCD Television
Eurovox
Use the remote and:
Menu>Config>DeleteData>DeleteChannels>OK>OK (pin = 0 0 0 0)
It will say please wait for channel delete
Use the remote and:
Menu>Config>DeleteData>Factory Default>OK>OK (pin = 0 0 0 0)
It will say please wait for factory reset and after 10seconds you will be returned to the scanning screen.
Sep 03, 2009 | StarTech.com StarView SV211K 2-port KVM...
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
Arris DCT6200 DTV Receiver Logo
467 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
