Question about Husqvarna Viking 1
How do i get into the back of a Viking Selectronic 190 and what kind lubricant to use
    Problem Solver:
  • 4 Answers
They require no lubricant and this is a sealed unit that cannot be opened easily
Posted on Jan 22, 2011
How to change under tension on Husqvarna optima 190 selectronic
The bobbin has a tiny screw on the side that is the tension setting. Turn it a slight 1/8 turn and test (a small turn makes a big adjustment). Be sure to mark the original setting of the screw before making any adjustments so you can back out the adjustments if it's not working.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Aug 21, 2016 | Husqvarna Sewing Machines
Would like to get a owners manual for my husqvarna 190 selectronic sewing machine. I am having trouble with upper tension and need to make sure I am threading it properly, any suggestions
Here's an ebay that has one for $ 15.00. There are others.
http://www.ebay.com/itm/Vintage-Viking-Husqvarna-Sewing-Machine-Operation-Manual-Optima-190-180-150-/191517822256?pt=LH_DefaultDomain_0&hash=item2c975a0d30
Generic threading:
START TO THREAD WITH PRESSURE FOOT UP. AS YOU THREAD GIVE LITTLE PULLS TO INSURE THERE ARE NO SNAGS.
1. Go from right to left.
2. As you feed you will come to the tension. Make sure it is fed through the tension disc or it won't work.
3. Feed through the take up lever.
4. Feed through the final holes to the needle. Final little pull to check for snags.
5. Put pressure foot down and give little tug. It should have some resistance, but not excessive. Usually four on the tension control is a good starting point.
6. Check your bobbin for pressure. Pull out the bobbin case and let it hang from your finger with the bobbin inserted. While you bob it back and forth it should extend one inch. Adjust the tension as you need to. Put one drop on the little ring under the case. (It looks like a race track).
7. As you use the machine you may have to adjust the upper tension as you need.
Feb 28, 2015 | Husqvarna Sewing Machines
Explanation of what all feet are for
Do you have a manual? If you do not, Google 0ptima 190 selectronic and download one. It will explain what all your feet are for or buy the "FOOT BOOK" from a Viking dealer and it will tell you every foot that has ever been made for a Viking.
May 29, 2014 | Husqvarna Sewing Machines
The bobbin isn't catching on my Viking Husqvarna 190
Your machine is out of time. You'll need to take it in to a professional to get it timed correctly
Nov 24, 2012 | Sewing Machines
Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Jan 16, 2009 | Husqvarna Viking 1
Sewing Machines Logo
209 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
