Question about Lakewood HV 18-c Floor / Box Fan
My lakewood high speed floor model HV-21T stopped running. After shutting off it started running again but shut off again and this time the motor and cage was extremely hot.Also are new motors available on line?
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
-Brandon
Posted on May 31, 2011
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
May 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Fan does not turn on low speed, middle speed. do I need a new motor?
if the motor works, you do not need a new one ! sounds like the switch is bad. if you only get high speed. have a good day !
Feb 12, 2011 | Lakewood HV-12-c Floor / Box Fan
All of the sudden my fan stopped working completely. It does have a lot of dust in it. It is 12 inches and says Model HV-9 C. I tried to plug it in several different plugs, still doesn't work.
take front off of fan. then blow the motor out good to get rid of dirt and dust. also when apart oil the front and back of armature, to make it run better.
Oct 20, 2010 | Lakewood HV 18-c Floor / Box Fan
Wht is the correct wiring (red, white, blue, black) for the three speed switch?
White is the common or neutral...
Black is the high speed...
blue is medium...
red is low speed...
hook them up right in that order....
heatman101
Aug 17, 2010 | Lakewood HV 18-c Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
I need a replacement motor, 60 HZ 2.7 amp, for a Lakewood fan Model HV-217SPC
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 28, 2010 | Lakewood MC-42 Fan
My lakewood HV18 just stopped. Spinning the shaft
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Sep 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Feb 01, 2008 | Zenith B27A11Z 27" TV
Lakewood HV 18-c Floor / Box Fan Logo
2,087 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
