Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a 1991 1200 sporters custom i bought a small tech and speedo. speedo works cant get the tech to work? please help.
  • Harley Davidson Master
  • 637 Answers
First of all, were you replacing the instruments or were you adding the tach.
Posted on Sep 21, 2014
    Brigadier General:
  • 5,158 Answers
Is the tach made for a car/van or a motorcycle ?
Posted on Aug 23, 2010
I have a LS1 gen3 in a wh holden statesman, the cluster works but the speedo doesntwhen tested on tech 2 i had speedo to the cluster but not to speedo on cluster.please help
More than likely the tiny electric motor that moves the speedo needle has failed, very common issue on GM cars and trucks.
Jul 06, 2016 | Holden Cars & Trucks
I have just bought a 1999 yamaha sr125,speedo and milage is not working.please can i have advice.this is my first bike and i want it fixed.help please.
Does the speed part work? If so, it is faulty and needs replacing.
There are speedo repair places.
http://www.guagerepairs.com/
Your speedo is cable operated as opposed to electronic and worlks by using a flexible cable with square ends that turns inside a sleeve. When speedos don't work it is usually because the cable wasn't attached properly and the square ends are not properly located at the gauge end or the drive end.
The link explains the best way to install
http://www.oldjapanesebikes.com/gt750/img/page-6/Speedometer_Repair.pdf
Jul 05, 2016 | Yamaha Motorcycles
05 elantra 2.0 auto speedo dont work replaced all 3 sensors and body to eng grd is my cluster bad or drive gear bad help please how do i replace drive gear in trans help
If i may ask why did change the sensor,did it show the the ABS light on the cluster?You need to perfom a cluster self diagnosis am not sure of the procedure on Hyundai since i am a Nissan Tech or perfom active test on the cluster,if not check the fuses.Back to sensors if you had an ABS light before and it cleared but still no Speedo then you might have bought wrong sensors,the ABS module can tell that there is a sensor due to resistance but as you drive it can't pick up your speed signal to the ECM
Apr 11, 2015 | 2005 Hyundai Elantra 2.0
2005 Yamaha V Star 1100 Custom speed sensor problem
Hi, TimandChrist for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1100 Speedo not working no idea
Repair Yamaha Star Speedometer Odometer Not Working
Yamaha XVS1100 Service Manual
OEM parts for Yamaha
Yamaha XVS1100R Owner Manual
Jun 22, 2012 | 2005 Yamaha V Star 1100 Custom
The speedo on my Triumph Speed Triple 955i has a fault in that it doesn't work after start up on some occasions. If the engine is stopped and started again, it works. Once it is working it continues to...
Hi, Christiancliff for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Triumph, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
03 955i speedo problem
speedo not working Problem Solving Tech Forums Messageboard Triumph Torque
Triumph Daytona 955i 2002 Service Manual
http://www.worldoftriumph.com/triumph-motorcycle-parts.html
Triumph Speed Triple Handbook
Jun 04, 2017 | Triumph 955i Speed triple Motorcycles
I bought a 1992 1200 Sportster and it didnt have a speedometer cable. It has a wide glide front in with a drag specialties mechanical speedo. I went to the Harley shop and bought a new cable but cant...
The is should be a speed drive unit on the axle that has a tab that sticks into a slot on the wheel. The lower end of the speedo cable screws into this unit.
Good Luck
Steve
Aug 28, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
The speedometer n my 1999 Sportster 1200 has stopped registering. How do I fix it?
This depends on whether it is an electronic speedo or a mechanical speedo.
The electric speedo has a sensor near the rear of the engine. Sometimes a very small piece of metal will get stuck on the end of the sensor and the speedo will stop working. Remove the bolt holding the sensor into the engine case and carefully pull the sensor out. Wipe it off and reinstall it. If the speedo still does not work, it's probably something in the speedo itself.
On a mechanical speedo, a cable from the front wheel drives the speedo. The cable or the speedo drive unit may be bad. To check the cable and drive, lift the bike off the ground, disconnect the cable from the rear of the speedo. Turn the front wheel and see if the cable is turning. If it is, it's probably alright. I'd still pull the cable out of it's housing and lubricate it with some grease. If the cable is turning, the cable and drive unit is alright. The speedo may be broken.
Jun 15, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Help!!i bought a new psp and i cant install custom firmware...
alright u dont have custom firmware u can not flash a psp 3000 so just get the chickhen mod it is limited but hey what works works right? anyways just look it up on google or youtube and u should find out how to use it i dont use it but my friend does.
Jan 09, 2009 | Sony PlayStation Portable (PSP) Console
Lands Phones Logo
41 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
