Question about Goodman CKL30AR30 Air Conditioner
Hi,Ice on the suction and discharge line in LG split a/c. Please help me to clear this issue. Thanks.
  • 139 Answers
First replace filter or check to see if its dirty ..is the blower in furnance on? their are a few reasons they freeze up. 1 dirty filter. fan not blowing ..dirty coil ..evaporator coil.. the one above furnance, or low on refrigerant AKA freon .turn off unit but leave fan run to defrost ice on coil replace filter ..remember that if it is below like 65degrees they tend to freeze up also if the unit runs all the time its prob froze up .after defrosting retry unit you will know if it worked within a couple hours..
Posted on Aug 22, 2010
    President:
  • 3,773 Answers
Check and clean condenser coils with good coil cleaner
Put exterior fan on it to veify it.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
How do i dismantle the aicon unit
First thing u have do is pumpdown the unit close discharge line wait for few seconds check the suction line when coolness of suction line goes also close the suction valve and then dissconect all power supply then u can remove copper tube and easily dismantle a/c unit.
Oct 05, 2014 | Mitsubishi MSZ-A24NA Split System Air...
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Conair mini split heat pump isn't cooling but has cold suction line but warm liquid line and is not freezing up the evaporator. Thinking a sucking reversing valve?? What could cause that? Both evapor
Make sure that your refrigerant charge is good first. Reversing valve has 4 pipes coming off of it. The one alone is discharge and centre of 3 is suction always. The two sides are the reversing pipes. One side should be same temp as discharge and other same temp (+-5F) as suction. If not then you have bypassing refrigerant in valve. Bad.
Jul 13, 2013 | Heating & Cooling
I have LSA 18TWASI LG make split air conditioner purchased two year back.Since then it was o.k. but now in this summer season ,when it was found that whole gas happened to leak , it was serviced and the...
It sounds like it leaked again and there's not enough refrigerant in the unit to cool. That's generally is what causes the cooling coils to ice up. Get your serviceman back and see if he can replace the coils. Repairing them is not a good option.
Apr 04, 2011 | LG Heating & Cooling
Hi, i need to disconnect a DeLonghi split system, type DEFS 71 EXU. I need to know how to pull the refrigerant back into the out door unit. any help would be greatly appriciated.
Pump down the gas.: Start the unit let it run for 5 minutes after compressor start working. In out door unit first close completely liquid line valve (Discharge line) and after 5 seconds switch of your unit ( Most important). Now close suction valve. Pump down completed. Helpful?
Jan 04, 2011 | Heating & Cooling
DISCHARGE LINE ICE MAKING
Check you air filters and make sure the blower is running. If everything is OK the refrigerant charge maybe low.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Bon-Air mini split 1.5 ton, suction and discharge pressures are equal. discharge valve has ice on it. and the suction and compressor are very hot.
Sorry to sat but the tech has no idea what he is doing. The metering device is in the discharge valve, making that line a low pressure, not high. If the "suction" line is hotthen it is running in heat mode.
Jun 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG Split Ac-Sprinkles water in roomafter a while of cooling
first check to make sure that the indoor unit is very slightly off level sloped to the drain area also turn off power and inspect the indoor coil with a flash light to make sure all the fin area is open the drain pan has two possible drain connections if they are both hooked up then the primary "lowest"
could be stoped up a blast of water or air to the drain line should clear out slime also make sure their is a trap in the drain line or the water will only drain dwhen unit is off hope this solves your problem thanks
May 15, 2009 | Heating & Cooling
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Goodman CKL30AR30 Air Conditioner Logo
283 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
