Question about KitchenAid KTT780 2Slice Toaster
The toaster doesnt work, light doesnt turn on. Have opened the toaster, but cannot see what is wrong with it. It is just over 2 years old.
I have Sunbeam 'Radiant Contol' TOASTERMATIC toaster. Must be 40 years old - and only recently stopped toasting. Is there anyone who might fix this - I think the radiant coils have burnt out. I live in...
There could a number of reasons why it has stopped working and depending on the problem it could be a simple fix but generally not. It is after all an old toaster as you realise. On the bottom is a model number AT-35 AT-40 or TA-J. It depends on what part is sentimental as the outside and ends and base can be transferred over to a working mechanism. I have a few of these toasters and think they are just great.
Sep 08, 2010 | Vacuums
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
Not toasting at all. Worked on 4 slices the nothing,
Rotate the dial all the way one then the other a few times. Maybe something behing it. It this is helpful, please post as such.
Jan 10, 2009 | Dualit CTS4E 4-Slice Toaster
Toaster burns everything
It sounds like the heating sensor is longer functioning and the toaster is probably kaput, unless you can find an independent repairman who works on small appliances. In my own experience even a pricey toaster last about 3-5 years. I had the same problem with the same brand, just a different style
Aug 15, 2008 | Cuisinart CPT-160 Metal Classic 2-Slice...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
KitchenAid KTT780 2Slice Toaster Logo
59 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
