Question about HP Computers & Internet
Reader error failure - HP Computers & Internet
    Guru:
  • 1,082 Answers
Ouch, this is not what you like to see.
This is often caused by a bad disk drive.
Disk drive manufactures have diagnostic programs you can download. Download Seagate disk tools from their web site. Burn a CD and boot your laptop with it. Run diagnostics.
If it says you don't have a Seagate disk, it will tell you the brand. Go to that brands web site, repeat above.
If you have a bad disk, then you need to replace it. On laptops it is fairly straight forward but you also need to restore your system. If you don't have restore disks, you'll have to buy them from the laptop manufacture.
Posted on Aug 22, 2010
Canon photocopy machine model ir 6055 system error 000302-0001
Title
Error in paper front shading
Remedy
  1. Connector disconnection/open circuit of the Scanner Unit (Reader).
  2. Connector disconnection/open circuit of the Reader Controller PCB (PCB1).
  3. Failure of the Scanner Unit (Reader).
  4. Failure of the Reader Controller PCB (PCB1).
Description
Error in shading RAM access, or the shading value is either below or higher than the reference level.
Aug 11, 2016 | Canon Office Equipment & Supplies
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Whats the meaning of error E0202 canon ir copier
Description
An error occurs during the Scanner Unit (Paper Front) HP detection operation (outward).
E202 -0002 -04 Title Scanner HP error
Remedy 1. Connector disconnection/open circuit of the Scanner HP Sensor (SR2).2. Failure of the Scanner HP Sensor (SR2).3. Failure of the Scanner Motor (M1).4. Failure of the Reader Controller PCB (PCB1).
May 11, 2016 | Canon Office Equipment & Supplies
E000719-0031 error code for canon ir c5250
E719 0031 00 Title Error in serial communication at the start of the New Card
Reader
Description Failure in communication with the serial New Card
Reader at start-up.
Remedy - Check if the cable of the serial New Card Reader is
disconnected.
- Take out the serial New Card Reader.
- COPIER > Function > CLEAR > CARD
- COPIER > Function > CLEAR > ERR
Dec 20, 2013 | Canon Office Equipment & Supplies
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
On a Nozzlehead Check: Printer failure ,error code
Hi
I have put a PDF files on my website for you to download.
And it for your printer Epson-R300-Manual.pdf
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and save it to your PC.
Click LINK= http://www.4all2sell.com/pdf/Epson-R300-Manual.pdf
You need a adobe reader to see this file If you not got a pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Office Equipment & Supplies
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
