Question about Acer AL2216W LCD Monitor
More screen resolution - Acer AL2216W LCD Monitor
  • 1,179 Answers
I have a solution to your problem, it is comprehensively explained in my published guide entitled How to set your Desktop Screen Resolution?
Hope this enables you to increase your resolution for a better picture.
If you are still unable to do so, then install the latest driver for your graphics card, either Nvidia or ATI
Thanks
damnor01
Posted on Dec 16, 2010
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
How to change the resolution
  • Native Resolution - 1280 x 1024 at 75 Hz
  • To change your screen resolution
  • Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  • Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  • Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
  • if not display come pls select esc button to revert resolution.(don't press Enter)
Jun 15, 2014 | Samsung Syncmaster 730B 17" Flat Panel LCD...
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Blurry computer screen
1) Check the screen resolution.
Right-click on My Computer, (or Computer), then at the bottom of the list click on Properties.
2) In the Display Properties window, click on the Settings tab.
In the middle, under -> Screen resolution, is it the native screen resolution for the laptop's monitor screen? (LCD screen)
Example: 768 x 1280
Don't know?
Use the computer you are using now, and look up a replacement LCD screen for your laptop. This info will tell you what the native screen resolution is....(Will just state screen resolution, or resolution)
Also......Look to the right of Screen resolution.
Color quality is supposed to be Highest (32 bit)
If it isn't, then click on the blue side arrow, and in the list click on Highest (32 bit)
Still no?
Then don't give up on me, we're diagnosing the problem remotely.
Come back in a Comment.
Regards,
joecoolvette
Jul 03, 2013 | Sony Computers & Internet
Change display properties
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
Aug 27, 2012 | Computers & Internet
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
Nov 13, 2010 | Intel D945GCCR Motherboard
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Acer AL2216W LCD Monitor Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
