Question about BenQ FP767 17" LCD Monitor
The color on my beige BENQ FP767 is blue i cannot fix the color schematics back to the default settings, please help
  • 11,361 Answers
Blue cast on the screen? Then check all the pins on both ends of the video cable, try it on another PC to make sure it is not video card problems.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 22, 2010
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
When I switch on my FP767 monitor the light appears as blue, but nothing on the screen.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL (BenQ makes Dell MONITORS) monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 21, 2010 | BenQ FP767 17" LCD Monitor
Says out of range
It is abut your videocard refresh rate.
Restart the computer in Safe mode and reset the videocard settings to default. (640x480 px) 60Hz.
Oct 02, 2009 | BenQ FP767 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
How to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Jun 13, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem
IT seems you are not technically trained in electronics.In this case it's difficult to explain via this board,Best you find someone to fix it for you,you can try contacting Benq Support locally.
Sorry for not being able to help.
Samir
Jun 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem - Power LED Blinks
Look for small power transistors 2SC5707 near yellow invertor transformers which go to backlight connectors.
But if problem is blinking power LED powersupply capacitors maybe an issue,check visualy and/or replacement.
Also fuse that maybe blown is not glass fuse near mains socket,It is semiconductor black or yellow colour labeled PFxxx near heatsinks of power supply secondary.
Please rate the solution and provide feedback.
Samir
May 25, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 contrast keeps appearing
The problem is with front panel switches.The contacts maybe leaky.You need to replace all the six switches.
Samir
May 21, 2008 | BenQ FP767 17" LCD Monitor
Benq fp767 backlight problem
I've repaired my FP767 just today. It had similar problem.
First of all I thought that I needed to replace CCFL tubes.
Then I noticed inflated capacitors in power supply.
I replaced them all and monitor works as new.
Apr 24, 2008 | BenQ T701 TFT 17" LCD Monitor
BenQ FP767 17" LCD Monitor Logo
77 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
