Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Saeco viennia super automatic coffee machine....coffee not coming out...grinds the coffee but no or very little water coming out then it shuts down....cleaned the brew chamber... not sure what else to do..thank you...machine is about 6 years old... joe
  • 1,089 Answers
Try open the grind adjustment knob to the max. # 16 and then try again. Push the buton after the water starts to flow until the fourth coffee, and then let it brew. If it clears and brews , turn the knob back to a # higher than what caused the problem. If that doesn't do it , you have a blockage in the brew head under the manifold, and that is an other fix.
Posted on Aug 22, 2010
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Saeco machine grinder
Due to the use the grinding burrs are slightly move and wire out. So I advice you to move only one max two step to more fine coffee grinding from the one you have and try the coffee.
The test you have to do is that for about 30 cc of coffee the time that the coffee will run should be about 20 to 22 seconds. If the coffee more faster you need more fine grinding. If the coffee run more slower than 28 sec you need more gross coffee grinding.
Good luck
Mar 23, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna deluxe espresso machine
Clean the ball and valve assembly located in the Brew Group. It ocassionally gets "dirty" and needs cleaning. Be careful you don't lose the glass ball which is very small. Use a q-tip or small wire for cleaning the tubular area.
Sep 18, 2008 | Saeco Vienna Espresso Machine
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
/Mirran
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
99 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
