Question about Neovo F-17C 17" LCD Monitor
THE SCREEN IS BLANK, THE YELLOW LIGHT AT THE BOTTOM IS FLASHING I HAVE UNPLUGED IT AND LEFT IT FOR A FEW DAYS AND PLUGGED IT AGAIN AND THE SAME SITUATION PERSISTS. THANK YOU FOR YOUR HELP
  • 11,361 Answers
Try it with another PC first to make sure it is not the video card problem.
Otherwise you will have to inspect the DC filter caps in the power supply and the backlight inverter circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Aug 22, 2010
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Feb 05, 2014 | Televison & Video
PS3 WONT WORK
u shudda listened when the chick told you to send it in...
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Start button flashes yellow - will not turn on
I have found that if the CMOS battery is removed and the unit unpluged for 5 mins (reseting the unit to default config) It will restart. The battery should not be replaced thus to maintain your date and time settings, it shoud not be unpluged for long periods.
Apr 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 22, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Mouse Stopped Working
Is there a button on themouse (probably on the underside) and on the receiver you can press to make the two parts pair up again?
Nov 26, 2007 | ACCO Brands Kensington® 72258 (72258US)...
Neovo F-17C 17" LCD Monitor Logo
88 people viewed this question
Top Neovo Computers & Internet Experts
Tom Chichester
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
