Question about ACE 3605GD Smoker
Where can i get a AZ002053 burner assembly for a smokey mountain smoker?
Weber grand cafe heat
Some tips here
Weber com Support Help Grilling Tips
You can ask them for manual
Weber com Support Manuals
Some tips for smpking
Top Ten Tips for Smoking
The Best Setup for a Weber Smokey Mountain Barbecue Smoker and Other Bullet Shaped Charcoal Smokers
amazingribs com
Watch this video
Weber Grills Smoking on Your Smoker
May 24, 2015 | Weber Grilling
HOW DO i CONVERT A CHARCOAL SMOKER TO A LP sMOKER
My advice would be: go to Landsman Smokey Mountain/search parts lists for their propane smoker/order the proper burner, mounts, regulator and hose. Assemble according to the Parts diagram. install a wood chip box. Happy Smoking.
Dec 15, 2014 | Landmann Smoky Mountain Two Drawer Easy...
How to fix a leak on a Great Outdoor Smokey Mountain propane smoker?
Goop will seal the hole and it will work (I use it for many fixes) the problem is that where there is a hole the metal is probably corroding and there is another spot that will go soon. If you can't find a direct replacement, have someone make one for you (unless you can do it yourself) until then get a tube of Goop (household) patch the hole and let it dry overnight.
Jun 22, 2012 | Grilling
Instructions for use of char-broil H20 smoker.
I takes lots of practice to use a charcoal smoker, but don't let that stop you! I go on professional competitions and started out by checking the "Virtual Bullet " website. This site is for the Weber Smokey Mountain cooker but you can get ideas from there. Hank
Jul 15, 2010 | Char-Broil Charcoal Water Smoker 4654301
How do I use it?
I've been smoking for over 10 years and basically use the Weber Smokey Mountain. You need lots of practice to make good "Que" but once you get the basics under your belt you too can make some awesome barbecue. I can guide you to the Virtual Weber Smokey Mountain site to get the basics. Google " Virtual Bullet" Enjoy...Hank
May 19, 2010 | Char-Broil Charcoal Water Smoker 4654301
Have a 2003 Smokey Mountain Series 36'' gas smoker and looking for part AZ001163 Wood Chip box and AZ001111 Water Bowl. Any idea how I can purchase these. I live in Wasilla, Alaska phone number...
For questions regarding replacement parts or service inquiries, please contact weber customer service at 1-800-446-1071 or email Support@WeberStephen.com
Apr 20, 2017 | Sport & Outdoor - Others
Need manual for Great Outdoors Gas Smoker
Company went out of business.
Dec 17, 2008 | Grilling
Gas shuts off
Try turning on the gas at the tank with the burners turned off. Wait a minute or two for the pressure to equalize and then turn on the burner and try lighting it. It should work. If not check the venturi and see if an insect or spider might have blocked it so the air mix is interrupted. It may be that your regulator needs replacement. If you have a gas grill that works your might try switching them if they have the same size fittings and see if it works then. New regulators can be found at LP gas dealers, hardware stores, and the big boxes like Home Depot, Menards, Lowes and Wall-Mart.
When turning off any gas grill it is best to turn off the tank first, then the burner after the flame is out. This especially applys to the tanks with the overfill protection device.
Good Luck
Dec 01, 2008 | Grilling
ACE 3605GD Smoker Logo
196 people viewed this question
Top ACE Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an ACE Grilling Expert? Answer questions, earn points and help others
