Question about HP DeskJet 5740 InkJet Photo Printer
Paper feeds only half way and stops. Pressing the resume button ejects that one and the next stops half way again. Thanks, R.
  • 390 Answers
SOURCE: lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Posted on Sep 01, 2007
Ajkill
  • 2035 Answers
SOURCE: Paper Jam issue
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 25, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 121 Answers
SOURCE: Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Posted on Oct 08, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
On the Ip4300 the yellow light flashes at 10 times intervals. The printer does not responde to anything. Thanks Dave
This is from Canon's web site...
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
May 04, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother HL 1240 Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Flashing lights on printer
The iP4300 manual says this for 10 flashes "
The size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A4, Letter, A5, and 5" x 7". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed." Hope this helps
Mar 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
HP PSC1510 Feeds paper half out then stops
Clean the roller that feeds the paper (located at the right side inside the feeding tray).
I did it ,with a cotton pad: first impregnated with water an soap, then only with water to clean the soap and then with a dry pad. I did making the roll to roll printing a page without paper in the try and continuosly presing the cancel/resume button.
Mar 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP DeskJet 5740 InkJet Photo Printer Logo
234 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
