Question about Magic Chef CTF2125 Top Freezer Refrigerator
Which side of a MCBR402S compressor is the low pressure side for recharging the system?
93 Allante AC Compressor won't come on to recharge system
On most models you would need to jumper the low pressure switch while you are recharging the system. There should be a low pressure switch on the low side line and a high pressure switch on the high side or on the compressor.
Jul 14, 2014 | Cadillac Allante Cars & Trucks
AC does not work 2000 Ford windstar
first thing check AC compressor fuse.the AC compressor clutch should engage when you turn on airconditioner if AC compressor dont come on and fuse okay compressor clutch is open or low on refrigerant you need check your AC refrigerant low pressure side and high pressure side need a manifold gauge set. best let garage check out AC system could need system recharged or could have leak in the system.
Jun 19, 2013 | Cars & Trucks
Need air cindition recharge, don't have cash to take it someplace, can you help with instructions to do this
YOU NEED A R-134 GAUGE SET TO CHECK LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.YOU ALSO CAN BUY A LITTLE CHEAPER GAUGE TO CHECK YOUR AC LOW BLUE SIDE AND HIGH RED SIDE AT ANY AUTO ZONE OR ADVANCE AUTO PARTS.WHAT YOU DO WHEN YOU GET YOUR GAUGE SET HOOK GAUGE TO LOW PRESSURE SIDE BLUE CAP PORT AND GAUGE TO HIGH SIDE PRESSURE RED CAP PORT.YOU CRANK CAR UP GET IT OPERATING TEMPERATURE.THEN TURN AC ON HIGH COOL LET RUN 3 TO 4 MINUTES.CHECK LOW SIDE GAUGE READING SHOULD BE 28 - 32 PSI. HIGH PRESSURE SIDE GAUGE SHOULD 199 - 228 PSI. THATS NORMAL CHARGE. SEE YOU CANT JUST RECHARGE AC SYSTEM UNTIL YOU CHECK IT FIRST YOU WILL DAMAGE SYSTEM .NOW YOU CAN GO TO AUTO ZONE PARTS BUY A CHARGE CAN WITH GAUGE AND HOSE.ATTACH TO IT.YOU NEED MORE THAN ONE CAN.WARNING MAKE COMPRESSOR IS RUNNING WHEN YOU TURN ON AC .BECAUSE IF COMPRESSOR NOT RUNNING CHECK FUSE AND AC COMPRESSOR RELAY.IF BOTH OKAY.YOU COULD HAVE OPEN CLUTCH COIL A FAULTY LOW PRESSURE SWITCH WILL CAUSE AC NOT TO WORK. IF LOW PRESSURE GAUGE BLUE SIDE PRESSURE IS 28 OR 30 YOU DONT NEED A CHARGE.PROBLEM SOME WHERE ELSE.BE SURE TO WEAR SAFETY GLASSES WHEN WORKING ON AC SYSTEM.
Jun 26, 2010 | 2004 Hyundai Elantra
I want to recharge my air conditioning in a 1991 cadillac deville
Here's what you do.
Get an R134a recharge kit or R134a recharge hose (with an optional gauge) that has the adapters to put on to the low side port located near the firewall on the passenger side.
If the system is down already, the computer may have disabled the compressor.
To reenable the compressor, disconnect the battery for a few minutes and reconnect.
Charge the system with about 2 or 3 11 oz. or so cans of R134a while the car is running and the temperature is set to the lowest (say 60 deg. F).
If your recharge hose has a gauge on it, the right pressure should be in the green area ranging from 25 psi to 45 psi on the low side when the compressor is running.
Jun 10, 2010 | 1991 Cadillac DeVille
Need to jump compressor on to recharge refrigerant
You should not have to jump compressor to recharge a/c system, when adding freon low pressure switch will kick compr on, if it's not kicking on or it read low freon on your dash, replace both low pressure switch's, both sit along fire wall from left to right on a thin a/c line, when replacing these switch's make sure what ever freon in system is recover.
Jan 21, 2010 | 1997 Cadillac Seville
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
Freezer and fridge not cooling
compressor not on most likely.listen for a low hum inside or low down close to the floor in front of it.If no hum its not on.depending on age you can install a hardstart for it and get more life out of it.
Sep 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigator not cooling coils clean and compressor working
check defrost timer control on older located on bottom by the condenser coils look at elect diagram to see if one is hook up
Sep 24, 2009 | GE Refrigerators
No power to the ac compressor
Have you checked the refrigerant level,If it is low,No power will be supplied to the compressor.
May 28, 2009 | 1998 Chevrolet Cavalier
AC has stopped blowing cold air. Compressor is working. Where is the recharge valve located?
There are two A/C refrigerant lines. The small line is your high pressure line and the larger line is your low pressure line.
Start at the fire wall and follow the "large " low pressure line to the compressor. The low pressure charge port will be some where on that line.
DO NOT try to recharge on the high pressure side ( small line )
Good luck, let me know.
Regards,
Apr 26, 2009 | 2001 Saturn L-Series
Magic Chef CTF2125 Top Freezer Refrigerator Logo
27 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
