Question about Karcher Plumbing
I have a K 2400 HH< actually don't have a pressure, I know that the problem is a pump, what you recommend: buy a repair kit or replace the pump?
  • 760 Answers
Depending on the problem. If there is no mechanical problems check valves and piston seals would make it like new. If there is any damage replace pump.You can get parts at www.pressure-washer-parts.com They offer parts, or a giant brand replcement pump. GOOD LUCK
Posted on Aug 23, 2010
Srmw 2.2g26. Can the pump be rebuilt with a kit?
There are two options for this pump regarding rebuilding it. You can purchase all of the repair kits individually, or just buy the complete replacement pump head with all components already installed. This is the easiest/most reliable way to address the repair of the SRMW pump. It is also extremely easy to install, and can be done in less than a minute since you do not even need to remove the pump from the pressure washer (this is the complete pump head that can be found online:
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Oct 03, 2013 | Briggs & Stratton Garden
Water will not shoot out....took the hose off and it still doesn't work
If this model has a quick disconnect coupling for the pressure hose opposite of the sprayer wand at the pump, remove with a wrench. Hook up the water hose, turn on he water , but don't start the engine. If it has a clog this will flush out the clog. Replace the coupler and hose, turn on the water first before starting the engine. If the pump builds pressure it will make the motor bog down slightly. If there's no change in the sound of the engine with water turned on, the pump will be damaged. If the motor bogs off and on and water sprays on and off, means there is an air leak in the pump. If the pump does not work at all with the water turned on, the pump will be burned up. Please don't take this in offense; but I've seen many power washer pumps damaged because the water was not turned on before starting the engine. Try these few steps and let me know if you get any pressure at all, if so it's probably an air leak. Good luck!
Jun 21, 2011 | Mi T M Mi T M CV 2400 Cleanmaster 2400...
I'm doing some repair on a Karcher model K 2400 HH. Are there any repair manuals or diagrams for them? I have been on many websites including the Karcher site and can find nothing. I know they want you to...
I find this link and gives a good breakdown of Karcher PW in ALL PARTS. It does not have K 2400, but try this link for K240. You can tell whether it covers your machine or not.
http://www.pressureparts.com/TreeView.aspx?node=71067&node1=72670&node2=76096&anchor=76096#76096
Mar 30, 2011 | Karcher Garden
Replace pump on a darcher k2400 hh pressure washer
There is a bolt item 8 below on the very end of the drive shaft that has to be removed before you can remove the pump assembly.
See page 16 item 8 of this Manual: (<-click and download
Then you should be able to remove the pump.
Thanks for using FixYa.
Kelly
May 11, 2010 | Karcher 2500 PSI Pressure Washer
How can i refill the air conditioning in my 2001 hyundai sonata
You can buy a recharge kit at your local parts store. The kit comes with a pressure gauge to let you know when the coolant level is good, over charged, or low. The kit cost about $25. With the kit hook up, it can't be hooked up wrong with the high and low pressure ends. You will be able to use this over and over, just buy new cans when you need to refill.
Apr 13, 2010 | 2001 Hyundai Sonata
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Plumbing Logo
165 people viewed this question
Top Karcher Plumbing Experts
paulcarew
obsteiner
JonSnell Electronic
JonSnell Electronic
Are you a Karcher Plumbing Expert? Answer questions, earn points and help others
