Question about Maytag LAT2300 Top Load Washer
Maytag washer LAT 9800 washer fills with water but agitation does not start-cycle time keeps on going with a groaning sound ,as if something is holding back the machine from working.what could be the problem and solution? any help appreciated
  • bajenam Aug 23, 2010
    Probably gave a wrong description of the problem. Listened more carefully-after filling is done,it makes a continuous and loud humming noise ONLY(not a groaning sound or something holding back feel)with the cycle clock going.Have set the dial at other settings such as spin and it makes the same humming noise.Have set it at rinse- it fills with water and then the same loud humming noise.Sorry for the wrong information.Will it change your diagnosis and repair suggestions? Thanks
    Bankim
    Thanks for your prompt response kelly.To answer your question-it does not agitate or spin,just hums and also clicks every few seconds.Does not sound like any thing is running other than filling with water.My skill level is negligible.Called a friend ,his guess is a bad lid switch. Your thoughts as a veteran tech. will be appreciated.Thanks again
    Bankim
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
If you can use a mirror carefully under the machine and see that the motor is actually turning both belts when it is supposed to be agitating. (CAUTION the pump belt is in the very front of the machine base.) I suspect that it is driving the belts normally.
Inside the transmission there is a nylon gear that drives the agitator shaft for agitation. It sounds like the nylon gear has stripped gear teeth. This can be repaired and parts are available but it is a major undertaking, time consuming and not cheap.
To repair this if the nylon gear has failed the top, agitator, inner and outer tubs, large lower pulley and transmission must be removed. I will say this is not your average repair. Let me just add that this washer can still serve a long service life if repaired.
(I personally own a LAT9700 and just spent the time and money to overhaul it 2 weeks ago) Your call on having it repaired or replacement i.e evaluation / comparison time..... . This repair if done correctly by a seasoned tech takes well over 2 hours of shop time so keep that labor expense in mind. I have worked on Maytags for over 40 years that started with the Family business.
Thanks for choosing FixYa.
Kelly
Posted on Aug 22, 2010
  • 1 more comment
  • Kelly
    Kelly Aug 23, 2010
    It certainly does. Here is my question... Does it agitate and spin yet make that loud hummong noise? Or there is no movement and the unit hums. This sounds like the motor is not turning at all. Here is what I would like you to do. Unplug the unit but do not disconnect the water lines. Tip the unit to the rear and block it up so that there is enough room to safely place your hand under the unit. Squeeze the drive belt together mid point between motor pulley and the large drive pulley. The motor is on a floating mount. Then let go and try to turn the motor by hand. WATCH for movement of the drain pump pulley AND the motor pulley.
    Note the large drive pulley will appear to turn free in one direction (agitation) and really really hard in the other direction (spin) attempt to turn the large pulley at least half a turn.
    If you can turn it by hand remove the blocks and place unit in original position. Test SPIN and see if you get the same hum.
    If the motor does not start there are few things that can cause this.
    Motor winding, bearing or motor switch failure
    Timer failure.
    I do not know your personal skill level so fo the moment I am keeping this pretty basic. I will be watching for any responses.
    Kelly
  • Kelly
    Kelly Aug 23, 2010
    It just hit me that... the motor may be running and the drive belt either broke or for some unknow reason came off the pulley. The motor might be running and the motor shaft it driving against the base of unit. You really need to look UNDER the base at the 2 belts. The belts are items 20 and 21 this link: http://www.appliancepartspros.com/partse...
    Kelly
  • Kelly
    Kelly Aug 25, 2010
    Jest doing a follow up. Were you able to figure out the problem with the information provided? There is more I can help with if you still need assistance.
    Kelly
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag LAT9800ABW
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Do not overload your machine, the manual will tell you the max load. Check to see if any hose has come loose from behind the machine; look inside from behind.
Sep 11, 2007 | Maytag LAT2300 Top Load Washer
Washing Machines Logo
282 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
