Question about LG WM-2277HW Front Load Washer
Code OE - LG WM-2277HW Front Load Washer
  • 37 Answers
Stephen 1787 --
You are getting this code because your washing machine has tried for more that 10 minutes to drain the water out of the machine. Most likely the cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
First make sure that you unplug your washing machine. To clean out the pump filter you must drain the washing machine water. Manually bail-out the water using a small bucket or basin. Then use a towel to sop up any remaining water. Remove the pump filter, clean out any debris, and rinse out the filter. Plug your washer back in and restart the washing machine. Ensure that your machine is properly leveled. Washers that are too far out of level may not drain properly. If you are still having problems, write back. -- SWT
Posted on Aug 22, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
I have a code that sa OE and dont know what it means
Check out this tip it will help explain that OE code
LG Washing Machine OE Error Code
heatman101
Sep 26, 2010 | LG Washing Machines
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG WM0642H Front Load
My machine is showing an oe code and won't drain
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
Jul 03, 2009 | LG WM2496H Front Load
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
147 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
