Question about Bosch 11318EVS 1 - 9/16'' 11 Amp SDS - Max Demolition Hammer
BOSCH 11318 EVS not turning? Hammer works fine.
2 Suggested Answers
  • 218 Answers
SOURCE: hello... I've rented a Bosch
You should only need to push the bit in. If that does not work grasp the chuck and pull back towards the handle than insert the bit and release the chuck. You remove the bit by doing the same pulling the chuck back and taking the bit out
Posted on May 09, 2011
Lube oil for bosch 11241 evs rotohammer
1 615 437 511 thats the number for your oil AND knowing that you must have this partnumber 1 617 000 430 if your machine has had the running hours then it will be made a much better time spending then change only oil.
the most important part is the hammer tube in the machine for which this absolute good air and oil is close
Feb 06, 2016 | Bosch Garden
Bosch 11241 evs rubber boot removal
  • Then first remove pos 21 if chisel is locked move the tool holder backwards as far as possible you see the rubber cap pos 21 can be released with a plier or little screwdriver then after that snapring pos 143 to remove with a shaft retaining ring pliers as little set it between the small groove between the two ends of the ring thats on the metal ring its on pos 31 a rubber ring beware PARTS pos 25 blocking elements 2 pieces are in most cases 1 or 2 are broken thats why its not release the chisel in most cases. , beware if this tool has had its working hours , its the best thing to sevice it a 1 617 000 430 a consumables kit and 1 615 437 511 a oil reservoir are not expensive and all the neccesary parts are to in this kit andits made repair more meaningful because carbon brushes and al neccesary o rings are in the kit. also the blocking elements and more . its much cheaper then the parts separate.
http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=7NpuAYB2&p_p_auth=9xkD3xxM&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMHVpYjMyYlY0O3NpZD12MElCS3pCTTZ4VzMwbWR6cXZzZDBEX0hxWW15eWZsWEpVT0NnTExzcVlteXliUG5QZUk9
May 25, 2013 | Bosch 11241EVS 1916" SDSMax Combination...
I have a Bosch 1617 EVS router, a couple of years old, one of several routers, so not a lot of hours on it. A minute or so after turning it on I get a burning smell. It doesn't smell when I run
Check the armature bearings, especially the lower one hear the collet. It's possible some of the liquid wrench got into the bearing and cleaned out the lubricating grease that's in there. If the bearing is dry or damaged, either from use or during the removal of the stuck collet it will cause the motor to work harder which causes heat buildup and eventually a burning smell. If you bent anything you would feel a very distinct vibration in the tool when you turned it on that wouldn't have been there before. The bigger the bend the greater the vibration.
Sep 19, 2012 | Bosch 1617EVS Router
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222 evs
Push the red button all the way in as far as it goes and turn the knob to the left (counter clockwise) past it's normal position. Then you can pull the knob out. When you replace it make sure that the pin part fits inside the slot of the shifting arm inside the tool.
Aug 07, 2012 | Bosch Drills
Hello... I've rented a Bosch 11318 Hammer drill and it did not come with a manual......could you please tell me how to insert the bit. thank you.
May 09, 2011 | Bosch 11318evs 11 Amp Sds Max Demolition...
I have a Bosh, model no. 11232 EVS Hammer Drill, but do not have the service manuel, and would like to know how to service it, how and when.
Many people service their hammer drill when it begins leaking, stops hammering, or just quits running. Bosch makes a service kit that comes with brushes, grease, and all the o-rings and seals their own technicians at the Factory Service Center use to rebuild the tool. 1617000263 is the part number for the service kit, and costs under 50.00 . The unit will have to be torn down and cleaned(everything forward of the armature). If you dont do it for a living, it can become quite a project. Try to avoid bringing into a service center disassembled, because they will charge you more than if you just dropped it off for a rebuild.
Nov 16, 2010 | Bosch Drills
I have a Bosh 11232 EVS Hammer Drill, but I have no instructions for servicing it. Can you help?
All the manuals for the Bosch Tools can be found a Boschtool.com Just search for your model and it should be there.
How much oil and what type goes back in the bosch 11241 evs
The best way is to find a Bosch service center and get the oil change kit. P/N 1615437511 this comes with a small bottle of oil and a top cover gasket. All you do is remove the top cover dump out the old oil and pour in the whole bottle of the new stuff. Couldn't be more simple.
Aug 01, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
Bosch 11318EVS 1 - 9/16'' 11 Amp SDS - Max Demolition Hammer Logo
102 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
