Question about Remington R9370 Electric Shaver
I haven't used my shaver for more than a year and now it refuses to charge. Nothing happens when I plug it in.
  • Remington Master
  • 1,600 Answers
Batteries are probably dead and need replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order two batteries
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
To replace, you will need to remove the back cover. To do so, remove the three screws on the back. One is easily visable. Slide trimmer up to see second screw. The third screw is tougher...you need to pry out the trimmer at the top where it flips out from the shaver body to get to it.
Once removed, you will be able to access the batteries. They are soldered to wirdes. Unsolder the old ones and solder in the new ones
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Aug 23, 2010
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
The shaver sat, in a safe environment, for about a year. naturally, the battery wasn't working, so I plugged it in to charge it. It's been charging for about 2 hours, but nothing seems to be happening....
The battery has died because it was left discharged for too long. If you can get a replacement battery you should if it is a reasonable cost compared with replacing the shaver. Can you get the battery out? If so I will try to help further
Mar 14, 2011 | Health & Beauty
My babyliss 789ou has lost the ability to set adjustment,this happened after travelling
This commonly happens to travelers. The voltage of electrical outlets differ depending on where you travel. Shavers bought in one country are specifically designed to handle the outlets of that country but plugging into a potentially higher output outlet you blow out the motor of your shaver which it seems like you did. The only real solution would be buying a new shaver. It had nothing to do with the shaver itself, simply a mix-up in charging the battery which caused the motor to overheat.
-Jord
Feb 28, 2011 | BaByliss Health & Beauty
My Braun tootbrush has never charges-i have a 240 & 11v shaver socket but nothing seems to happen when i plug it in?
When charging a device on some type of charging block you need to plug it into a regular 110 socket as the block has the correct modifications in it for the device that it charges. This 11volt shaver socket is for older shavers that dont charge up you just plug them in and use them.I hope this helps you ....good luck
Oct 13, 2010 | Vacuums
I have a philishave hq 6849 which is about 5 years old. I charged it yesterday and today it is "dead" when I plug it in the mains the greenlight comes on but nothing else happens. Is there an internal...
Yes, there is an internal battery and it can be replaced. You will find the battery you need at shaveroutlet.com. See link below
You will need one or two batteries depending on the internal configuration of your model.
To open the shaver, you will need to remove the two screws on the back of the shaver. Once the back cover is removed, you will be able to access the battery pack and circuit board. You will need to unsolder the old battery pack from the circuit board and solder in the new one
Feb 03, 2010 | Philips Philishave HQ6849 Electric Shaver
HQ7830 Philips Shaver. Does not turn on, bu light shows when char
your battery is probably bad or you may have a loose connection inside. you will find batteries at shaveroutlet.com
Jan 09, 2010 | Philips Health & Beauty
I have a Braun 360 and I haven?t had a problem with it for over 2 years, now all of a sudden the cleaning station is making continuous clicking sounds and it will not register, clean or charge the shaver....
I can't suggest anything for cleaning station but for direct connection of shaver please follow the possible solution below.
Your Rechargeable batteries (built in) could have been dead..and needs to be replaced.Normally they die in 2 to 3 years depending on the frequency of usage.
But before taking it to a repair shop ,make sure you check the power cord / adapter as well,
because sometimes one of the lead cracks at the point that it attaches to shaver for charging,which the power cord/adapter needs to be replaced.You can ask one of your friend to borrow its adapter for testing purposes.
If you wish you can describe the problem more details than I may suggest something else.
Regards.
Nov 22, 2009 | Braun 360° Complete Electric Shaver
I purchased phillips series 7100 on 27th Nov. 2007 and it is now not holding the charge. I have adherd to the 8hr. charging & there is nothing wrong with the supply to the razor. As this is within the...
It sounds like your batteries are no longer able to hold a charge and are in need of replacement. With all rechargeable shavers, once the batteries are incapable of holding even a minimal charge, the shaver becomes unable to be used, sometimes even wih the power cord plugged into an outlet. My Braun shavers all worked for about a year after it would no longer operate on battery power alone, then the shavers all stopped working regardless of being plugged in directly to an outlet.
As you mentioned you are still under the warranty period, I would suggest you contact the company and request warranty service for your shaver.
if you weren't under warranty, I would advise getting the replacement batteries and doing a repair yourself.
Hope you find this Very Helpful and best regards!
Sep 11, 2009 | Philips Health & Beauty
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
Cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Oct 27, 2007 | Braun 360° Complete 8985 Electric Shaver
Remington R9370 Electric Shaver Logo
130 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
