Question about Canon Office Equipment & Supplies
I have a U150 5bk error and the cartridge is illuminated red. Can I get around this? The cartridge has plenty of ink. Thx
  • Canon Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
Cartridge error
replace the cartridges with new ones and clean the contacts.. its the inks... replace both of them at the same time
Mar 31, 2010 | HP Officejet 5610 All-In-One InkJet...
NEW CARTRIDGES _ RED LIGHT SUPPLY ERROR? Can't read cartridges
Magenta cartridge has a piece of thick plastic around the computer chip on the cartridge which I couldn't remove. Need to send back.
Jun 23, 2009 | HP LaserJet 3600n Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
HP C3150 error flashing....not printing!
You may have got a bad ink cartridge, I would try changing it again to see if that helps!!
Jun 19, 2008 | HP Photosmart C3150 Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
116 people viewed this question
old marine
old marine
