Question about Refrigerators
Sanyo model SR-4310W Accidently penetrated the plate that freon is distributed. The bottom of the small freezer section. Noticed immediately gas escaping. Attempted to remove panel but the pipe or hose upper right corner does not budge. 1. Can it be removed for replacement? If so, how? 2. Can the freon be recharged? 3. Will the cost to repair be as much as buying a new one? 2.
  • rcmckee Aug 22, 2010
    Thanks for the info. The plate is on the inside. The bottom plate at the freezer level.
    Bob
  • Refrigerators Master
  • 43,501 Answers
To answer your questions...
Yes, the panel can be removed, but it will take special tools to do it...
It can be replaced and the system can be vacuumed and recharged...
Check with a local appliance reapir company for sure but my guess off hand would be somewhere in the neighborhood of a 1000 bucks to replace and recharge that unit...
So that should give you an idea as to whether you want to go ahead with the repair or to buy new...
heatman101
Posted on Aug 23, 2010
    Genius:
  • 1,340 Answers
You cannot recharge with freon until you get it fixed as it will just leak out again.Your best bet for now is to call an appliance repair center,tell them what happened,and they should be able to give you a ballpark $ amount over the phone.There probably is about a $50 house visit,and repair centers have a minimum parts price markup of 20%.Your refrigerator sounds new enough but if it was made probably pre-1995ish,the freon will be expensive.I said that year because that is the year cars were switched over to the newer freon.If they do not give you a cost estimate with the information you provide,call someone else.Call someone else anyways just to see who may be cheaper.They see all kinds of stuff and should have a good idea of what it will need.Although from your description,I cannot tell if the plate is inside or in the back so when you call,just be as descriptive as possible and I am sure they can be fairly accurate in the estimate. Good luck! Greg
Posted on Aug 22, 2010
I have a Sanyo Compact Refridgerator Model number SR-8k. I accidently punctured the rim of the ice tray area and gas came out. is there any way to fix it? Thank you, Rick Caldwell
not sure , but try you tube. put in your problem in the search bar and put you tube on the end and it should take you to a video with the problem you are having!! you tube is a life saver as well as a money saver!!!
Jan 29, 2014 | Sanyo Ref SR-8K S
My sanyo SR 4310w fridge won't work after laying it on it's side.
Try standing it upside down for about an hour. Fridges have oil in with the Freon to lubricate the compressor and if laid on it's side the oil can drain through the tubing all into a spot that doesn't lubricate or over fill the compressor depending on which side it is laid on. sometimes the remedy is to reverse the process that caused the condition, specially the compressor having too much oil. it is a slow drain back so give it some time and it usually works.
Aug 12, 2012 | Sanyo SR-4310 Compact Refrigerator
Ro@hotmail.comtemp fridg& frezer will chang 30 to 40 degrees if you open either door it will take a long time for for temp to drop
The compressor is the part which cools the refrigerator.---------- First i will explain the working procedure of your sanyo refrigerator.---------- In the refrigerator, there is a part called compressor, the compressor is the part which cools the freezer section, When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold.--------- So the freezer section cooling/ freezing is must.If freezer is not getting properly cooled or not getting cooled, then fridge section will show the low or no cooling problem.--------------
In your refrigerator, its quite possible that compressor is got weak, nor complete faulty but little bit weak.So when you open and close the fridge or freezer door , the compressor is not that strong to maintain the required temperature.So its working hard to cool inside temperature, but its not doing it quickly as it should.---------.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- ----------------
There is manual reset procedure, sometimes the ice gets frosted all over and blocks the ventilation's for cool air to pass from one section to another, and this also causes problem.So directly going for compressor inspection, before that you can try manual reset procedure and see if that helps.---------
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked. -------- This should help. Thanks.Helpmech.
Aug 22, 2011 | Sanyo SR-3620 Compact Refrigerator
My Sanyo refrigerator (model SR-4431S) isn't cooling like before and certainly will not make ice... While scraping ice from the freezer compartment up top, I accidentally made a small puncture in the back...
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Oct 22, 2010 | Sanyo SR-4310 Compact Refrigerator
I need a new freezer section. Mine has a leak.
Hi.
Try first doing a complete defrost and cleaning the bottom of freezer after defrosted.
The freezer has usually a drain hole that may get clogged with ice and debris.
Part availibility will depend on your location. Try the seller below , they ship worldwide:
Appliance Parts -Research, Repair & Replace.
Nov 13, 2009 | Sanyo SR-366 Compact Refrigerator
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
Poked hole in icebox
Unfortunately you cannot just plug a hole in what I assume is the pipes carrying the cooling liquid around the unit .
If you got a spray out of it you have lost the gas and the cost of removing the pipework plus the re-gas will probably be as much as a new unit
Old saying "never poke a refrigerator matrix with anything sharper than your elbow" , sorry !
Jun 17, 2009 | Sanyo SR-4910M Compact Refrigerator
Sanyo Eclipse refrigerator (Model# SR-4433S)Has puncture hole in Freon Tray for freezer. Does anybody sell replacement part?
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Oct 15, 2008 | Sanyo Refrigerators
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
