Como colocar los codigos para el jwin jd-vd145
Benimur
  • 6966 Answers
SOURCE: nesesito un codigo para un
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
Bajanguru
  • 7752 Answers
SOURCE: como remuevo el codigo
you need to have the phone unlock , you can do this online at www.mobile2mobile.net or www.unlockitnow.com, take the phone to a mobile service center and ahve them unlock it for a fee...unlocking is not a free service
Posted on Jul 02, 2008
SOURCE: codigo de seguridad para ingreso y su funcion
puedo desbloquear una radio kdc-mp522 sin el control remoto
Posted on May 02, 2009
parkerd
  • 79 Answers
SOURCE: perdi el manual de mi control remoto universal GE RM 24912
que remoto? va a la website de el remoto und mira por los codigos ahi
Posted on Jun 11, 2009
rulds2008
  • 3866 Answers
SOURCE: me gustaria tener el codigo de mi tv KLH digital
Esta Television nesista su propio remote y esta es un problema si usted no la tiene pero si puedo compra una y asi es la unica solucion por esta problema usted cuento la sitio www.remotes.com si puede ayudar en muchos aspectos. Si puede comprar un remote que lo functiona por esta tele es que esta fabrica KLH es moy rado y no tiene la supporte usted esta buscando esto no es problema mia es un problema de frabricante porgue ellos nada mas vende y cerra sus puetos a cliente. Espero que esta informacion ayuda usted pardon mi forma de escribe yo no sabe mucho espano por favor dajar sus votos y propio commentarios positivos Gracias por su visita a fixya.com, Saludos
Posted on Nov 18, 2009
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Que sinigfica po442
Hola:
P0442 - Evaporative Emission Control System Leak Detected (small leak)
Lo del codigo es una falla del control de emisiones puede ser que el tapon de gasolina ya no este cerrando bien o alguna maguerita del canister se desconecto, no es nada que ocasione gran falla. Esto indica una fuga de vapor de combustible en el sistema de control de EVAP. De hecho, la filtracion puede ser de un agujero tan pequeno como 0,04" de diametro. El sistema de emision (EVAP) de control impide el escape de vapores de combustible del sistema de combustible de un vehiculo.
Los vapores del combustible son enviadas por medio de mangueras a un filtro de carbon para su almacenamiento. Mas tarde, cuando el motor esta en marcha una valvula de control de purga se abre para permitir entrada de la aspiracion para extraer los vapores de combustible en el motor.
Sintomas: Es probable que no se dara cuenta de los problemas de manejo.
Causas: Un codigo P0442 medio mas probable de uno o mas de los siguientes ha ocurrido:
Un gas suelto o colocado indebidamente el tope
Un disconforme de gas de cabeza (es decir, no de fabrica / marca original)
Una pequena fuga / agujero en una manguera de vapor de combustible / tubo
Otra fuga pequena en el sistema EVAP
Ventilacion defectuosa o-ring
Posibles soluciones: con un P0442, la reparacion mas comun es:
Retire y vuelva a instalar la tapa de la gasolina, borrar los codigos, y la unidad por un dia y ver si los codigos de volver.
De lo contrario, vuelva a colocar la tapa de gasolina, o
Inspeccione el sistema EVAP de cortes y agujeros en los tubos o mangueras
Espero que esta informacion le sea de ayuda. Suerte, y recuerde calificar esta respuesta.
Gracias por usar FixYa.
Jul 15, 2012 | 2000 Ford Explorer
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Feb 28, 2011 | DISH Network IR Remote Control
Los pasos a seguir para progamar el ontrol dish al televisor? y los codogos para el tele RCA
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el contol de DISH Network a su T.V el procedimiento es el siguiente: Oprima el boton de T.V localizado en la parte de arriba de su control hasta que los demas botones se enciendan en rojo, una vez encendidos ingrese el numero de codigo que tenga para la marca de su televisor seguido por el signo de numero (#) el boton de T.V debe de iluminarce 3 veces, despues usted puede intentar usar su control y deberia funccionar. Los codigos que puede programar a una television marca RCA serian los siguientes: 503, 020, 633, 805, 725 y el 627. Si tiene algun problema me puede contactar directamente a kimberly.escobar@dishnetwork.com este link tambien le puede servir de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos y ayuda en como programar el control. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Nesecito codigo de un control remoto CHUNGHOP PARA UN TV LG
en la pagina chunghop estan los manuales con los codigos. yo necesito un manual de tv itt-nokia sat 203 o alguien que me explique como se programan los canales y el timer.
Jan 07, 2010 | Zenith MBR3447 Remote Control
El codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Dec 19, 2009 | Televison & Video
Perdi el manual de mi control remoto universal GE RM 24912
Jun 11, 2009 | Emerson EWF2703 27" TV
Codigos
codigo de tv sony para control universal rca modelo dcrcr450
Dec 09, 2008 | Televison & Video
Nesesito un codigo para un dvd marca jwin grasias
1. Press SETUP
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
Jwin JD-VD130
2. Press 1, 3, 6, 9
5. Press ENTER
2. Press PROG
3. Press ENTER 3 x
6. Press STOP
2. Press SETUP
3. Press 1, 3, 8, 9
5. Press SETUP
2. Press 2, 8, 1, 2
4. Press SETUP
Jwin JD-VD145
2. Press 9, 7, 3, 5
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
no known hacks
Mar 18, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
