Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
My Homelite trimmer won't accelerate. Idles but dies when I accelerate
  • 7 Answers
Common problem with most small two strokes in garden equipment is that they often have a mesh spark arrester screen in the exhaust, the screens clog up with coke and stop the engine from breathing, give the screen a clean and check the exhaust port for coking if the screen is not clogged. If the port is coked up then carefully scrape it and reassemble. If the problem is not coke then it will be carburation, either tuning, clogging or a diaphragm needs replacing.
Posted on Aug 22, 2010
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
I have a Homelite bent shaft trimmer. When I try to take off the nut to replace the line spool, I am turning over the motor and it nut won't come loose. Help
where the shaft meets the head there is a bolt, star shaped, take the bolt off and with a screw driver put it into the teeth of the gears and then turn the bolt. Tim
May 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My Homelite grass trimmer idles fine but when I open the throttle it stalls. How do I fix this?
Its sounds like it is running rich. Adjust your high speed adjustment screw. If the unit is older think about buying a carb rebuild kit, they run about $12.00 at your local fix it shop and if you are not in a hurry online for about $8.00 give or take S/H.
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
May 30, 2009 | Homelite Garden
Homelite trimmer dies every time I squeeze the handle
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
1,049 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
