Question about Maytag Neptune MDE5500AY Electric Dryer
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
  • 37 Answers
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Posted on Aug 22, 2010
  • Sal De Sep 19, 2010
    if the model number starts with mde it's electric if it starts with mdg it's gas
I have a Maytag Nepyune dryer model# MDG4000BWW. The drum turns, the ignitor glows but the gas does not always ignite. When the ignitor is glowing, if I wiggle the wire going into the 2 prong coil, I here...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Dryers
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
Maytag won't dry on any cycle
if you have gone that far you have it fixed
since you diagnosed that there was flame you can fix this really easily
unplug the unit
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083&diagram_id=678789#d678789
look for the two parts 7 and 8
those are going bad and will need to be replaced
hope this helps
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Maytag Neptune MDG4000BWW GAS DRYER
In the state of New Jersey there is an appliance store called abbot appliance parts. Call with make, model #, and serial # and they will help you. The phone # is (732) 244-2040 and the web site is http://www.manta.com/coms2/dnbcompany_dqpq2f I hope this helps. Don,t forget to rate my answer. Thanks.
Feb 21, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MDE5500AY Electric Dryer Logo
220 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
