Question about Kenmore Dishwashers
The start button is blinking and when you push cancel, it stops. Then when you try to start it, it just starts blinking again.
  • 3 more comments
  • thehubbles6 Aug 23, 2010
    I did what you said. All the lights lite up and the lock was on. I had to push cancel to be able to do anything. I tried to start and the same thing happened. Start light flashing.
    I tried the first thing (heated dry, start, cancel at the same time) nothing happened.
    Same with the second.
    Looking for other ideas to fix my dishwasher.
    665.17013400
    665.17013400
  • Kenmore Master
  • 2,605 Answers
Whirlpool built ( Kenmore, Kitchen-Aid, Jenn-Air, etc. ) dishwasher electronic control “blinking start light”
Hello, Welocme to FixYa.
The most common reason to experience the symptom described here is a often overlooked yet simply a faulty door switch.
The part to repair is typically only $10 -$15 at most appliance part retailers. The factory authorized part number is # 8269209.
What happens is the switch is not indicating to the control that the door is closed, hence not allowing the unit to start...exactly what it is designed to do.
You will need to remove all the #20 torx head screws around the inner door panel to separate the panels.
Once done, remove the rectangular plastic protective cover over the control and switch assembly, and there lyes the micro switch.
If you check local brick & mortar retailers or on-line depots such as “searspartsdirect.com” “repairclinic.com” or “appliancepartspros.com” to name a few you will find the micro switch I am referring to here.
**Please turn off the breaker panel before service is done to the unit...safety first**
Of course I should add one could experience these same symptoms if the door where in fact not closing or the latch itself is not contacting the switch inside the door.
Let me know how you make out and what you find.
Thank you for choosing FixYa for your repair needs and good luck going forward.
Macmarkus :)
Posted on Aug 23, 2010
  • Kenmore Master
  • 3,247 Answers
It is most likely a fault with the door switch which is failing to detect the door is closed. Please provide model no. of the kenmore dishwasher.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Aug 23, 2010
    Press the HEAT DRY and START/CANCEL pads at the same time, with the selector set to RINSE ONLY(Quick Rinse). The dishwasher will then step through the test cycle. Pushing the START/CANCEL pad will advance the dishwasher to the next step. If this wont solve the issue then press Quick Rinse-Heated Dry-Quick Rinse-Heated Dry in sequence. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    It seems that the issue is with the control panel going bad however, before replacing it you can blow air with the help of hair dryer so that if there is any moisture it blows it off.
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
Lights Blink washer wont start
Check user manual for programme reset , but poss. hold start button on for minute or try same with cancel button.
Nov 02, 2009 | Washing Machines
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Jan 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
