Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Power Cord keeps tripping because somehow water is in the cord. Tell me why and how this happened? We have a new big one that's 25,000 BTU (I think). Any suggestions on how to fix this? hunbrata@otelco.net
    President:
  • 3,773 Answers
Make sure it is draining correctly in the bottom back. Sometimes the fan sprays the water on the cord.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 22, 2010
Koldfront 12,000 BTU Heat/Cool Window Air Conditioner - WAC12001W power keeps tripping cord gfi
That is a big unit. Is the outlet itself supplying sufficient amps?
Sep 04, 2016 | Heating & Cooling
Power cord blew where it connects to the washer. See below.
I am not sure what bracket you are talking about. The normal setup is the electric cord goes through a metal connector and connects up to a terminal block. I think the bracket you are talking about may be the connector where the wire enters the washer. If this is the case you will need a new connector and a new power cord. If you go to a store like Lowe's or Home Depot and go to the electric dept just tell the salesman what you are trying to do and he will show you the parts you need. I also think the origination connector was to tight and movement of the washer caused it to cut into the wire causing it to short out and trip the breaker.
Feb 01, 2016 | Dryers
I have an Amana PTAC ac 15000 BTU that has stopped, the power cord keeps tripping. I removed the power cord and plugged it in to the socket and the breaker did not trip, any clues. I'm thinking of jus
I think you've gotton your moneys worth with ten trouble free years. The power cords safety device is a bit more sensitive to a high resistive short to ground than your breaker is. I would suggest that there is exactly that: a high resistive short to ground within the cabinet of the PTAC. It has been years since I have been on a PTAC call and am unable to suggest specifics. But if you are competent and capable of using a DVOM, open up the unit and begin a systematic approach of determining the problem.
The FIRST thing I'd do is check the motor and the compressor with a digital megohmeter. Sometimes their problem will only show up with this sensitive device.
Dec 28, 2014 | Amana PTC153B35AJ Air Conditioner
Frigidaire FRA 155MT1 melted the extension cord and surge protector
You must use a heavy duty power cord with this unit as it draws alot of amerage. Most regular extension cords csnnot handle the amperage and overheat or melt.
Jul 07, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
Brought 25000 BTU AIR CONDITIONER MONTH AGO power cord tripped and will not power back up!!
I have seen those End -of -cord built in GFI's fail like that , in the past I have just replaced the cord, but one month old is warranty issue
Jun 26, 2011 | Kenmore Heating & Cooling
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
25,000 btu not working brand new
unit was taken back to the store no warrenty people out of 10 called recomended by the manufacture wanted to fix it store took it back
Jul 01, 2008 | Frigidaire FAS185N2 Air Conditioner
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
198 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
