Question about Samsung SGH-A877 Impression Cell Phone
Samsung Impression Backlight Intermittent The Backlight stopped working yesterday but it flickers dim and is very dim now. In a pitch black room i can barely see it. how can i fix this without replacing the phone? I just got this phone almost 2 months ago on 7/3. Thank you! Jon Oyola
SOURCE: I have a Samsung Impression SGH-A877. It's frozen - Black screen
Hi! Most probable the software is broken, so you need to go to a specialized service and get it resofted.
Posted on Dec 12, 2009
SOURCE: samsung impression t9 bug, is there a fix please?
Please perform a master reset on the phone which may solve the problem - it did on my phone, at least for now...
Please follow the link for the master reset:
https://www.wireless.att.com/support/tutorials.do?tutorialPage=page2&universe=att&deviceId=11030&tutorialsCategory=Getting+Started&tutorialId=727440
Posted on Jan 04, 2010
  • 11 Answers
SOURCE: I need to replace the lcd screen in my Samsung Impression.
take it to the service
Posted on Jan 23, 2010
SOURCE: i'll charged everyday my samsung mobile phone
change battery or check the network mode
Posted on Apr 09, 2010
  • 240 Answers
SOURCE: the touch screen on my samsung impression has
replace it under warranty ...has a 12 mnth if it is an att phone and less than a year old call 1-800-801-1101
Posted on May 18, 2010
Sound on but no picture
Is the screen pitch black or a blue/grayish ? Dim the lights in the room, and shine a bright flash light on the panel. Turn on the set, if you see a faint picture, you have a backlight issue
Dec 13, 2012 | Philips 52PFL7403D 52 in. LCD HDTV
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
NC2400 screen flicker
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | HP Pavilion zd8000 Notebook
Dim display in samsung monitor
When the LCD monitor display is dim or flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 06, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
My laptop monitor flickers ramdomly....the grafix
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 14, 2009 | HP 510 Notebook
Screen goes black when plugged in
The high pitch sound is most likely a faulty inverter. Most defective screen are caused by a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Dell Inspiron E1505 Notebook
Intermittent video problem on acer extenza 5620.sometimes video display backlight will work sometimes it fails.
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
May 09, 2009 | Acer Aspire 5670 Notebook
Samsung SGH-A877 Impression Cell Phone Logo
157 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
