Question about HP Photosmart C5180 All-In-One InkJet Printer
Printer is no longer printing from the magenta cartridge. I have changed the cartridge and run the cleaning cycle 4 times and still not red. What else can I try?
  • HP Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
  • Ross Bennett
    Ross Bennett Jul 19, 2014
    can't get the carriage to move. It is just the red that isn't printing
  • Ross Bennett
    got the carriage lined up, cleaned it and still not working. Have to stop now and try later. Thanks for your advice.
2 Suggested Answers
  • 3 Answers
SOURCE: Kodak Easyshare 5300 Printer prints magenta tinted pictures
1 800-474-6836 this is a support number for HP products. They may be able to help you here or guide you to another source.
Posted on Feb 01, 2009
I can't get my hp L7680 to print red
If you have tried everything else, remove the printhead and run it through a 15 minute cycle in an ultrasonic cleaner in hot de-ionized water. Dry the PH very well with a hair dryer on low heat. I am assuming a good, new cart here, not a refilled dried out one, of course. I do not own this particular printer, but they are all about the same. I own the 8600
Jul 19, 2014 | HP Officejet Pro L7680 All-In-One Printer
Replace pixma printhead
Print heads on this model run about $80 on ebay. Your best bet is to first replace the magenta cartridge even though it may appear to still have ink in it. After that, go into the maintenance menu and run a full cleaning cycle several times. This may clear your clogged print head.
Apr 18, 2014 | Canon Pixma MG8120 InkJet Printer
All colors print except the Magenta. I have run the cleaning several times to no avail. The print quality check shows black yellow and blue, not even a hint of red. I hane replaced the Magenta cartridge.
It's really hard to say without knowing a bit more.
When and how did this happen?
Did you keep the machine idle, without using it for some time?
Lack of regular use causes the jets to clog up because of dry or drying ink.
Did you try refilling the cartridge?
Not all ink is universally suited.
Are the contacts clean and unobstructed?
First of all, don't waste any more ink running the cleaning cycle. It's rarely of any use when the condition is this bad.
There is a cleaning kit available with a special cleaning solution and it has never failed for me. It's cheaper than a new ink cartridge. :)
The catch is that, you will need a used ink cartridge and you will need to put some of this solution where the ink was. Then run the cleaning cycle or even try to print.
You'll get all the little accessories, like a tiny drill bit, some syringes and a bottle of clear solution.
The included instructions are not hard to follow.
I suppose the worst case scenario will require a trip to the service depot.
Feb 17, 2011 | Brother MFC-465CN InkJet Printer
Canon LBP5000 lack of Red (magenta)
Searched on web for same problem on HP2600 printer and found a sight that explained how to fix it. It is caused by the mirrors getting dirty. Magenta is the first one affected because it is on the bottom and points upwards. Requires printer to be pulled apart and mirrors cleaned. takes about 1 to 2 hours. HP2600 printer seems to be the same as Canon LBP5000.
Jul 07, 2009 | Canon Office Equipment & Supplies
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
MFC 210c problem with Magenta ink
I had a similar problem with my black ink. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
1220c Ink blockage
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Nov 15, 2007 | HP DeskJet 1220c InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
425 people viewed this question
Seeker5211
Seeker5211
