Question about Troy-Bilt Pony Garden Tiller
Pony 1979 oil seals on the gear box shaft how to pull
I have an oil leak from the engine. what could the problem be
Check the sump gasket at the rear of the sump tension sump bolts. Check that the rocker cover gasket is not leaking down the back of the engine and giving the appearance of a sump leak. Rear crank seal would be another point of leak and front input shaft (clutch shaft) seal leaking. Check the engine oil level and correct if necessary and check gear box oil level and correct if necessary. If you have an auto the oil will be pinkish and indicates a torque converter to gear box seal leaking.. Either of the shaft seals will require the box removal for repair.
Apr 05, 2013 | Cars & Trucks
Replace oil seal on transfer box
You don't mention the make or model but normally you have to pull the gear box to replace the internal seal which stops oil moving from the gear box back. If however it is a output shaft seal remove the flange and remove the seal with the box still in the car.
Apr 01, 2013 | Cars & Trucks
Skoda gear selector assembly manual gearbox 1998 felicia please show design and possible solution to oil leak from gear box end
Normally there is a seal of sorts here (it may be a felt seal or a rubber flap) but I find that if there is a problem here I check firstly the oil level in the gear box and the viscosity of the oil in the box Remove the filler plug (plug in the side of the box ) and drain until oil is level with the bottom of the threads. Best replace oil with a known viscosity oil for you gear box.
Apr 01, 2013 | Skoda Cars & Trucks
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
Mar 04, 2011 | Troy-Bilt Pony Garden Tiller
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a 1979 rm 250n it runs for about 20sec than sounds like its not geting fuel than dies it never did that un'till i toped off my gear oil and now it seems like gear oil is com'ing out of my exhaust
have you over filed it with gear oil???...check......if this does not fix it...you may have a crank case oil seal gone...& its sucking oil from the gear box in...if so its a engine strip to do both oil seals...
Mar 18, 2010 | Suzuki RM 250 Motorcycles
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Micra gear box Cv joint relacement
this easy, drain oil from gear box remove that drive shaft (u need a ball joint splitter)
replace gearbox seal, pry out old 1 with screw driver, gently tap new in, oil edge of new seal 1st. replace oil, ps dont leave to long as will damage gearbox when lack of oil
Aug 09, 2009 | 1994 Nissan Sentra 4-Door
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
24 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
