Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Unable to print Photos Says paper wrong size setting How
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
ECAXDOMO
SOURCE: Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Posted on Nov 28, 2007
JULIANFIX
  • 975 Answers
SOURCE: Problem getting the printer to print with the correct alignment
is the printer connected to the your PC ?? ARE YOU PRINTING THIS SIZE directly from the PRINTER ?? AS soon as i get an answer from you , Ill tell you what to do next , thanks AJ
Posted on Apr 22, 2008
  • 40 Answers
SOURCE: unable to print envelopes
On the word program you should change the size of the page to fit to an envelope, otherwise it will not work.
Posted on Dec 20, 2008
rulds2008
  • 3866 Answers
SOURCE: I am unable to print a 6x9 envelope.
Make sure you:
1: adjust paper size on printer and in the program.
2. pull levers toward envolope on feeder.
If you did all of this then chances are you have a bad feeder sensor and the printer would need to be repaired but I am quite sure this is not the case.
Thank you
Posted on Sep 01, 2009
SOURCE: trouble printing envelopes on kodak esp3 printer
Put a few small pieces of tape on the back on the envelope and tape it to the paper, print a test run of the adress and tape the envelope over the adress in the correct spot.
Posted on Feb 22, 2010
I CANNOT GET IT TO PRINT 6X4 PHOTOS FOR ME. IT KEEPS TELLING ME THAT I HAVE THE WRONG SIZE PAPER
The default setting for 6x4 photos is 100mmx150mm paper. If the machine does not detect paper that size or has not been told where to find it, the machine will report a paper fault. Refer to the manual on the CD that came with the machine esp Ch2 P14 and Ch4 P22 for help in this. If you don't have the CD you can download the manual from the Brother Website.
Apr 10, 2016 | Brother DCP-J315W Inkjet Multifunction...
My mfc 615w brother printer says i got wrong paper size have it set to 4x6 and will not print photos
You can attach photo to full size sheet (as an option),
if a document is too small it may not detect and will not
print.
Oct 28, 2013 | Brother MFC-640CW All-In-One InkJet...
Photos are not printing to correct size
May i know the model # of the printer.
You can also try this. When you click on Print button and the window pop up - Click on printing preference and check the Size of paper in the Advance/feature tab.
If you find any other size you dont want, set it to the correct size you want it to print.
IF you want to make these changes permanently, Click on START Button and click on Control panel and open Printers folder - Highlight the printer icon and right click on it and click on printing preferences and change the paper type.
Regards,
Suhail
May 20, 2012 | Epson Office Equipment & Supplies
It won't print photos correctly because it only prints part of the photos
While this may be a mechanical fault, and if so a service call is going to be required to fix it, it can frequently be caused by software settings for the printer drivers or for the software being used at the time the photo is being printed.
When you select print from the software the usual response is for the printer driver's dialog box to appear. Within that box is a radio button which is usually marked "Page Setup". Selecting that button will access settings for various paper types [which can effect the problem you are having if the wrong one is high-lighted] as well as various other feature settings which can effect the printers output.
The support website for your specific printer should have information on what settings to change to realize desired results.
In software, like Photoshop for instance, settings for image size can effect the printed end result if the settings are a mismatch between photo size selected and the photo paper being used [unless there is a "fit to paper" option checked in the aforementioned printer driver page setup dialog box]. Like having those settings set to print an eight by ten print on four by six paper, for example. These settings should be checked to make sure your selected photo print size matches the paper you are printing on.
Hope that helps.
Feb 04, 2010 | HP Photosmart C3180 All-In-One InkJet...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
My HP Photosmart C5180 All-in-one Printer - Scanner - Copier is not printing in the size i want it to. I have selected the default setting of 'fit to fill paper size' and i have selected what size paper i...
have you check the software parameters and you printer parameters?
I'll explain: when you launch a print usualy via file>print or ctrl+P you get a "software" menu and in that menu you have something like advanced parameters that leads you to your printer parameters. Maybe one of them is wrong.
If not check you file format, what softare do you use to print?
Jul 18, 2017 | Office Equipment & Supplies
Printing photos
Check the settings in the application you're trying to print from. Make sure photo paper tray is not engaged if you are printing docs.There is a conflict with Wordperfect giving you the 'wrong paper size' message. You need to either upgrade the firmware or Wordperfect to the latest version
Mar 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
222 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
