Question about Lexmark X4270 All-In-One InkJet Printer
Getting error code 1203. what is that? cant find manual...HELP Lexmark X4270
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have an error message #1203. What do I need to do?
The 1203 error indicates a problem in either one of your cartridges or between one of the cartridges and the printer. This article will help you determine the cause of the problem and how to resolve it: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers.
Apr 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I keep on getting error # 1203 what does this mean?
Error 1203 indicates a problem with one of your cartridges. Refer to this article from the Lexmark website on How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. I hope this information has been helpful. Thanks.
Jan 06, 2011 | Lexmark X4270 All-In-One InkJet Printer
Ive a lexmark x4270 tried to copy says consult user guide for error #1203 and i dont have a users guide. anyone know what i need?
The error #1203 on the Lexmark X4270 indicates a problem with one of the ink cartridges. You can try to check this link - http://bit.ly/ckmSbC - for the steps that will help you resolve the problem. If it still the small I would suggest contacting Lexmark Technical Support. Thanks.
Aug 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
My lexmark all in one is stating error#1203 how do i fix the problem its a x4270 machine i was getting a fax and next thing i knowed was fax did not come thru and error#1203 poped up
Here's an article in the Lexmark website that will guide you on what to do when have Error 1203 on the printer. Just click on this link: http://bit.ly/ax8swM. Make sure to follow the instructions carefully. But if all else fails, I suggest you contact Lexmark at 1-800-LEXMARK (1-800-539-6275).
Apr 29, 2010 | Lexmark X4270 All-In-One InkJet Printer
Need UsersGuide for Lexmark X4270, ?code 1203? on LCD panel!
cant find a user manual, only install manuals :(
from reading on your error it seems to point to an ink cartridge issue have a read of some of the following links
http://www.fixyourownprinter.com/forums/printer/38960
http://www.fixya.com/support/t131154-error_1203
loads more, just search lexmark x4270 error 1203
May 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270
This may be due to communication issue. Below link may be able to help you to resolve this issue..
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
Nov 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Dear Rica,
These steps are for a Lexmark 4200 Series, but I suspect they will work for your printer as well:
Cartridge Error: 1203
Your print cartridge has a short.
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Cheerup and Be Happy always
Mar 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
