Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stopped with 1 minute left and I cant open the door
  • Whirlpool Master
  • 8,220 Answers
Remove the bottom panel and clean out the pump. Use the tech sheet to diagnoseWasher stopped with 1 minute left and I cant open - fe39f5c.jpg8c815e6.jpg
Posted on Aug 22, 2010
3 Suggested Answers
  • 43 Answers
SOURCE: I stopped my washer with only 1 minute left by
unplug the machine from the mains socket this will reset the machine
hopefully it will allow you to open the door
Posted on Oct 18, 2009
  • 274 Answers
SOURCE: with 1 minute to go,
your going to love this, your pump is blocked due to hair or dog hair.so first cancel load now turn knob and change to a quick wash now unplug wait ten-seconds and the door lock well shut off,get a bucket (told you would love this) wring out and put clothes in bucket,now scoop out water and put draino-max gel about a third of the bottle and let it sit over nite,now run washer on Heavy-Duty load Hot water,it may take a few times,(are washer does the same and this works. and then do a quick wash(no clothes) then you can do wash again
Posted on Aug 29, 2010
Gltf2940fs1 machine stopped with 1 minute left in the cycle, could it be the door latch or motor control board
I appreciate your post, friend!
Based off the information you have provided your Frigidaire washer, GLTF2940FS1, stopped with 1 minute left in your cycle. This could be a potential issue with your door latch, control board, or a miscommunication within your washer. I would recommend a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If that does help correct your issue you may need to consult with a technician for proper diagnosis and repair. This may help you avoid any unnecessary part purchases. -Matt
Mar 11, 2015 | Frigidaire Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer stops w/ 19 min. left to finish and door pops open.
the same thing happened to our washer and a friend told us to take off panel below door and there's a opening that's covered with a circular plastic cover, open manually and remove all the junk that's accumulated from all washes, careful it may leak a great deal of water! Try that if anything else, unless you've already had it serviced!
I'm looking to try and solve yet another issue with the same washer...
Mar 31, 2009 | GE Energy Star WCVH6260F Front Load Washer
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
