Question about Lands Phones
Electrical problems with my Zanussi dishwasher.
  1. Dated 04/05/08
  2. Recently, I have put an enquiry for some one from Fixya.com to help regarding my dishwasher. Because sometime have passed, I decided again to put to your attention all the information regarding the trouble that I am presently having. Firstly, for about a year, this D/washer after running for about half an hour, it tends to switch-off the main circuit breaker (salva vita). After repeating this fault various times, I decided to see what was doing this fault. Near the water inlet for the side fitted water tank, I found two pin rusty holes on the inner panel. This water inlet runs above the connection for the heating element and after examining carefully the mentioned connections, I found the terminals corroded. I cleared carefully the mentioned parts and repaired the side panel not to let again any water passing through the side pin holes.I put the D/W on test and filling with water, and running for about an hour, it went from 'normal' to 'intensive' position without switching off the C/breaker. Yesterday, I again tried the machine,but it doesn't run, both from the water inlet electrical part or the main motor, although the main switch indicates that the machine is ON. Could it be that some electrical component on the mother board went wrong. The electrical board is BITRON - TES 202 LS. Sir, I have solicited your help and look forward to your valuable information how to solve this problem at the earliest and again be able to acquire the valuable service that was giving at home for the last three years. Thanks.
catriver
  • 878 Answers
SOURCE: Dishwasher won't turn on - HELP
Daniel, you have a thermal electronic fuse that sits on the side of the control board. More than likley this fuse has blown. You will have to remove the screws on the inside door and seperate the panel. The control will have a cover that will unsnap. On the control board you will see the fuse toward the right mounted to the top side. Part number for the fuse is 8269213. Why don't you look up the part on the net so you can identify what your looking for. Make sure to cut power to the dishwasher before going in there...Catriver..post back.
Posted on Sep 04, 2006
  • 87 Answers
SOURCE: Wash Motor Keeps running after water pumps out
You have a bad control board in the unit.
Posted on Jun 08, 2007
jsrock516
  • 5911 Answers
The dishwasher should have a thermal fuse mounted to the control board behind the operator console. It is a small silver colored device attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like thta, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacment kit (found at most appliance repair stores) that had thicker wires. If you post back with your model number (located inside the door opening somewhere) I can do some reasearch to be sure. And...I'll see if I can locate a part number for you. Let me know.
Posted on Nov 13, 2007
  • 47 Answers
SOURCE: VSX 7000A connects domestically but cannot connect internationally
Please check with your Internet Service provider. They might have a firewall which blocks the ports used for video conferencing
Posted on Apr 08, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Posted on Apr 21, 2009
My zanussi dishwasher DE6854 doesnt seem to be heating up .Not been cleaning very well lately put in a dishwasher cleaner .The heat of the water didnt break the seal on the cleaner.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 16, 2011 | Zanussi 24 in. DE6850 Free-standing...
I need to know if there is a site where i can download the cd rom drivers for a compaq presario 1200
I would think the compaq site would have all the drivers you need. They normally do.
Jun 07, 2010 | Compaq Presario 1200 Notebook
Where can I get a manual for my zanussi aquasave dw24
Your model did not appear on my search. Here's a link to Zanussi DWs, check your model number again and check here:
http://www.fixya.com/support/zanussi/dishwashers
Best regards, --W/D--
Aug 18, 2009 | Dishwashers
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi ZT685
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Dec 21, 2007 | Zanussi ZT485 Built-in Dishwasher
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
