Question about Garden
I have a Ryobi HT 26 hedge trimmer that I haven't used and can't find the manual to figure out how to start and use it. How can I get a replacement manual?
ctf1800
  • 4402 Answers
SOURCE: i have a black and decker hedge trimmer g25?
just take it to a electronics service shop that can resolder it for you
Posted on Aug 05, 2008
  • 3 Answers
SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Posted on Sep 22, 2009
#1 Taper
  • 1040 Answers
SOURCE: One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 26, 2009
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
Tip
Ryobi starting problems
If youtr ryobi petrol/oil mix machine will not start then check these out first.
1 . No spark change the plug but dont forget to check the plug gap.
2 . Still no spark change the HT lead
3 . Clean fuel/mix
4 . Lastly check the on/off switch for ware or rust and clean if ness
on Jul 29, 2010 | Garden
I Have a 26 cc ryobi hedge trimmer. I cannot find any where to oil the thing. I've just been oiling the blades. I know its a 2 cycle but shouldn't there be some where to oil the blades other than dir
check to see if there is any holes in top or bottom of bar to grease or oil, if not there should be screws on bar to remove cover to gain access to blades, also on bottom of engine there is a cover useully with 2-3 screws holding it in. remove cover to grease gear mechanism, do not remove gears inside.
Dec 01, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Please tell me exactly how I mix the gas and oil for my 22 in gas hedge trimmer Ryobi Model RY39500A HT 26. What type of gas, what type of oil. Also can I buy this premixed?
If you go to your local home center in the lawn care section they will have these little plastic bottle of two cycle engine oil they treat a gallon of gas if this is your only machine that mixes gas and oil you probably will not use a whole gallon in a season and you should not keep the mixture for to long it will not last. So doing some simple math and looking at back of container try to mix the ratio down if a whole gallon is not needed. Good Luck...
Sep 05, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
TrimmerPlus 720r Manual
Mine would start and run on the primer gas then die. Replaced the plugged fuel screen under the flapper valves on the single large screw cover of the carb. Runs well now
Aug 30, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi cs26 won't start
My 39500 will not start. I change the plug and replaced the fuel lins and bubble
Aug 13, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
My petrol weedeater/trimmer wont start
a few easy steps does it spark if not change the plug
if it doesnt spark now it could be a split in the HT lead so change that
Make sure u have clean petrol/oil mix
If still no luck check the on/off switch for rust or water
if damaged clean
Jul 28, 2010 | Ryobi Three Trimmer Combo
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
